Capacitive Soil Moisture Sensor Wemos ESPeasy
Everything about esp8266 and more.
JHO01
Target OS: Raspberry Pi
Domoticz version: 49700
Post by JHO01 » Monday 09 July 2018 17:14
Finally got the capacitive soil moisture sensor working in Domoticz
Hardware:
-capacitive soil moisture sensor, does not corrode (Aliexpress)
-Wemos D1 Mini
-connect moisture sensor VCC=>5V (Wemos), GND=>G (Wemos), AUDT=>A0 (Wemos)
Software steps:
Domoticz:
-Create Virtual Sensor, Leaf Wetness (because I like the little green icon); note IDX (in my case 1883)
Wemos:
-Flash Wemos with ESPeasy
ESPEasy:
-Config: Connect to your wifi network
-Controllers: Connect to your Domoticz HTTP
-Devices: add Analog input - internal, !st GPIO-14 (D5) enabled,
Do NOT enable send to Controler.
Memorize Name sensor (in my case Soil) and # name of Values (in my case Analog)
Add formula: (840-%value%)/425*100 (The A0 value is varying between 840-425, Dry-Wet)
Submit
-Tools, advanced, check rules, Submit
-Rules: add
on Soil#Analog do
 SendToHTTP,192.168.2.30,8080,/json.htm?param=udevice&type=command&idx=1883&nvalue=[Soil#Analog]
endon
Submit.
Now the number below the Leaf Wetness icon is showing the moisture percentage
Done
RPI-3, Z-stick Gen5, RFlink, 1-wire DS18B20, Fibaro switches, various RF-433 sockets, , BMP018
JHO01
Re: Capacitive Soil Moisture Sensor Wemos ESPeasy
Post by JHO01 » Friday 27 July 2018 9:25
Next challenge is to make the capacitive moisture sensor water proof. Have a look at my banana collection
1) cut out some plastic of the connector and clamp and solder a telephone wire:
2) Use a 2 cm diameter hose
3) Fill up the inside with silicone
