Domoticz crashes (segfault) since upgrade (stable)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
jmbjmbjmb
Post by jmbjmbjmb » Sunday 08 July 2018 15:42
Since I upgraded to latest stable a few days ago, my domoticz setup crashes with a segmentation fault error. I've tried using some combinations of -loglevel/-log / -verbose options but all I'm getting is :
2018-07-08 15:32:35.070 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-07-08 15:32:35.073 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2018-07-08 15:32:35.078 Status: Startup Path: /home/pi/domoticz/
2018-07-08 15:32:35.253 Sunrise: 05:57:00 SunSet: 21:52:00
2018-07-08 15:32:35.256 Day length: 15:55:00 Sun at south: 13:05:00
2018-07-08 15:32:35.259 Civil twilight start: 05:16:00 Civil twilight end: 22:33:00
2018-07-08 15:32:35.262 Nautical twilight start: 04:20:00 Nautical twilight end: 23:29:00
2018-07-08 15:32:35.263 Astronomical twilight start: 02:50:00 Astronomical twilight end: 00:59:00
2018-07-08 15:32:35.266 Status: EventSystem: reset all events...
2018-07-08 15:32:35.870 Status: PluginSystem: Started, Python version '3.4.2'.
2018-07-08 15:32:35.919 Active notification Subsystems: gcm, http (2/13)
2018-07-08 15:32:35.926 Status: WebServer(HTTP) started on address: :: with port 8080
2018-07-08 15:32:35.992 Status: Proxymanager started.
2018-07-08 15:32:35.998 Status: Camera: settings (re)loaded
2018-07-08 15:32:36.009 Starting shared server on: :::6144
2018-07-08 15:32:36.014 Status: TCPServer: shared server started...
2018-07-08 15:32:36.016 Status: RxQueue: queue worker started...
2018-07-08 15:32:38.016 Status: EventSystem: reset all events...
2018-07-08 15:32:38.021 Status: EventSystem: reset all device statuses...
2018-07-08 15:32:38.023 Status: DarkSky: Started...
2018-07-08 15:32:38.277 Status: PluginSystem: Entering work loop.
2018-07-08 15:32:38.824 Status: Python EventSystem: Initalizing event module.
2018-07-08 15:32:38.829 Status: EventSystem: Queue thread started...
2018-07-08 15:32:38.833 Status: EventSystem: Started
2018-07-08 15:32:49.057 (DarkSky) Temp + Humidity + Baro (Temp REDACTED)
2018-07-08 15:32:49.086 (DarkSky) Wind (Wind)
2018-07-08 15:32:49.111 (DarkSky) UV (UV Index)
2018-07-08 15:32:49.147 (DarkSky) Rain (Rain)
2018-07-08 15:32:49.162 (DarkSky) General/Visibility (Visibility)
2018-07-08 15:32:49.191 (DarkSky) General/Custom Sensor (Solar)
Segmentation fault
Any idea what else I could try doing to help troubleshooting ?
Also, if I start with a fresh domoticz.db (i.e., I move mine somewhere) then domoticz works just fine (without any of my setup of course) so I am thinking that the new version does not like something currently stored in the DB.
thanks for your help
devros
Re: Domoticz crashes (segfault) since upgrade (stable)
Post by devros » Sunday 08 July 2018 17:10
Try disable events and python plugins... my crash was similar and because of broadlink python plugin
brain
Target OS: Raspberry Pi
Post by brain » Sunday 08 July 2018 18:13
have you got the broadlink plugin working again?
devros
Post by devros » Sunday 08 July 2018 19:50
no i switched to python script with recorded commands, and works without problems :)
jmbjmbjmb
Post by jmbjmbjmb » Sunday 08 July 2018 19:53
I've reinstalled the current stable from scratch which works fine until I upload a backup of my database. The new install has all events disabled by default (or at least that's what it looked like) so that does not seem to be making any difference. If someine could help me figure the proper parameters to have a thorough debugging level in my logs maybe I could come up with more hints. thanks
devros
Post by devros » Sunday 08 July 2018 20:20
in your first log is python plugin system enabled, maybe try to disable darksky too...
jmbjmbjmb
Post by jmbjmbjmb » Sunday 08 July 2018 20:26
I just did a reinstall + database backup upload on a rpi3 and it seems stable. My original domoticz was running on an old rpi I bought in 2014 (cant remember which revision it is, one with only 512MB of RAM).
I would very much like to keep domoticz running on that old rpi. What do you recommend ?
Bernd
Domoticz version: 3.8153
Post by Bernd » Friday 13 July 2018 16:13
I would very much like to keep domoticz running on that old rpi. What do you recommend?
Say bye bye to the old one and safe yourself wasted hours.
Raspberry Pi B3 (Stretch) with boot from USB stick - no SD-card inserted
RFXCOM RFXtrx433E, firmware version = 1022
jvandenbroek
Post by jvandenbroek » Tuesday 17 July 2018 14:03
jmbjmbjmb wrote:I just did a reinstall + database backup upload on a rpi3 and it seems stable. My original domoticz was running on an old rpi I bought in 2014 (cant remember which revision it is, one with only 512MB of RAM).
Just put the latest Raspbian stretch image on it and you should be fine.
jmbjmbjmb
Post by jmbjmbjmb » Wednesday 18 July 2018 14:19
I do run apt-get upgrade/dist-upgrade on a regular basis so that should be the same shouldn't it ?
jvandenbroek
Post by jvandenbroek » Sunday 22 July 2018 11:32
jmbjmbjmb wrote:I do run apt-get upgrade/dist-upgrade on a regular basis so that should be the same shouldn't it ?
Theoretically yes (the dist-upgrade part), but when encountering issues like this it's better to just take a backup of your running config and put a clean image on it. That way you know for sure there is no old stuff left behind which potentially conflicts.
Users browsing this forum: No registered users and 4 guests
