cannot switch icons after upgrading to 4.97
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
mrohner
Domoticz version: 4.9700
Post by mrohner » Sunday 08 July 2018 11:45
I used to select an icon for my on/off switches such as door or garage door or TV icon. Now I cannot select any
https://www.dropbox.com/s/l0vntuowv7aci ... z.jpg?dl=0
felix63
Target OS: Raspberry Pi
Domoticz version: 3.8275
Re: cannot switch icons after upgrading to 4.97
Post by felix63 » Sunday 08 July 2018 12:21
Hi, obvious question but did you clear your caches and restarted your browser? Secondly what choices do you expect to have? I think - if I remember correctly - that this option gives you the possibility to use customized icons to replace the defaults.
If you recently did a clean install of domoticz your customized icons might have been lost. Check 'Setup > Custom icons' to see if your custom icons are there. If they are not there that might explain things...
mrohner
Post by mrohner » Sunday 08 July 2018 13:10
Cleaning the browser cache helped. Some icons lost
