Omnik Inverter - Additional data
TommySunny
Target OS: Raspberry Pi
Domoticz version: 3.8153
Post by TommySunny » Saturday 07 July 2018 10:35
I'am using the Wouterrr script to acquire the data from an Omnik inverter.
Everything works like a charm however when I look into my inverter either via the inverter interface or the via the portal I see that more info is available.
I mean like the AC output Voltage, the grid frequency (Hz).
I don't know how to adapt this in the code.
Did anyone already changed the script or knows how to do this?
sincze
Domoticz version: 4.9700
Re: Omnik Inverter - Additional data
Post by sincze » Sunday 08 July 2018 15:39
Using Pass2php since 2016-12
LAN: RFLink, P1-Port, OTGW, MySensors
USB: RFXCom, ZWave
WIFI: Mi-light Wifi-Bridge, Sonoff, ESP8266, Xiaomi Gateway
Solar: Omnik Inverter, PVOutput
Video: Kodi clients with Harmony HUB
Sensors: You name it I probably got 1.
TommySunny
Post by TommySunny » Monday 09 July 2018 9:57
Yep, I used this to get things working.
But the AC output (V) en frequency output (Hz) are not in the list and I was wondering if these could be added in some way.
Since I'm lacking the skills to do as such in Pyhton I was wondering if someone on this forum had already done this.
sincze
Post by sincze » Monday 09 July 2018 10:20
mmm nicely noticed. Let me check.
As I think I DO have those numbers for you.
I assume if you test with LiveStats.py (wouterrrr) you see those values presented in the cli?
USB: RFXCom, ZWave
sincze
Post by sincze » Monday 09 July 2018 11:13
The following should be possible with Omnik Inverter:
USB: RFXCom, ZWave
Users browsing this forum: febalci and 3 guests
