How To Access Older Log
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
hendryman
Target OS: Raspberry Pi
Post by hendryman » Friday 06 July 2018 9:54
I realised at 9am that a switch turned off at 4am (i can see 4am in the energy log of the switch). However, I can't access the text log in the domoticz web interface for that time, it only shows me 8am and later. I've searched here on the forums, on google etc, but no one could point me to the location of the logfile on the raspberry pi.
Questions:
#1 Is the logfile on the file system - and, if so: where?
#2 If the logfile is only in the database: how can a view the older entries?
Re: How To Access Older Log
Post by waaren » Friday 06 July 2018 10:40
Questions:
The location of the logfile on the file system is defined in /etc/init.d/domoticz.sh
cat  /etc/init.d/domoticz.sh | grep "\-log"
will show you where it is on your system. (If not disabled by a # at the beginning of the line)
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
gordonb3
Domoticz version: Custom
Post by gordonb3 » Friday 06 July 2018 10:59
Interestingly it appears that you may not have one. The log file needs to be specified on the command line and there is no default when you omit that.
hendryman
Post by hendryman » Friday 06 July 2018 15:33
i'm able to get the log path just like you said:
pi@raspberrypi:~$ /etc/init.d/domoticz.sh | grep "\-log"
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
but i can't read the log because the file specified in the prefs does not exist:
pi@raspberrypi:~$ cat /tmp/domoticz.txt
cat: /tmp/domoticz.txt: No such file or directory
very weird... how could i fix this?
Post by waaren » Friday 06 July 2018 15:39
Remove the # at the start of that line and restart domoticz
hendryman
Post by hendryman » Friday 06 July 2018 16:42
obviously... <sigh> thanks a lot! it works now.
i ended up moving the hole thing over to syslog according to this instruction:
https://www.domoticz.com/wiki/Set_up_Domoticz_to_syslog
Users browsing this forum: No registered users and 5 guests
