machinon theme
vamp
Re: machinon theme
Post by vamp » Saturday 06 October 2018 13:26
Hi there,
I installed the latest beta but i can not found the new icons...
And the left top Domoticz icon is a bit ugly... :) your screenshots the theme is look mutch better! How to do the same result?
OK the browser flush cache is helped :)
But found a another bug:
the "last seen" line is missing.
Ehh i found it in theme settings... :D No more problem...
Ronker
Target OS: Raspberry Pi
Domoticz version: 4.9700
Re: machinon theme
Post by Ronker » Saturday 06 October 2018 13:57
Hi there,
I have cleared the cache but still get the domoticz icon instead. Had to replace the image folder
EdddieN
Re: machinon theme
Post by EdddieN » Monday 08 October 2018 13:13
updated to zeplin a darker blue bar plus also added a notification icon. The icon only appears when something (yet to be decided) needs to be decided by the system, like an unplanned reboot, etc..
11101101 - www.machinon.com
EdddieN
Re: machinon theme
Post by EdddieN » Tuesday 09 October 2018 19:53
Here is a thought, I just saw this post: http://www.domoticz.com/forum/viewtopic ... 68#p193764 which notifes via dzVents about a reboot or similar. Would be nice if these could be tied up on a 'Domoticz notification center' where things like reboots, warning about file systems (or even temperature), basically anything that is related to the operation of Domoticz and the RPI (or whatever hardware).
I have something similar in my NAS and I found it quite useful.
EdwinK
Re: machinon theme
Post by EdwinK » Tuesday 09 October 2018 19:57
Looking a bit strange, but with a refresh it's fixed.
Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | RFxcom | Dashticz V2
EdddieN
Re: machinon theme
Post by EdddieN » Tuesday 09 October 2018 20:04
EdwinK wrote:Looking a bit strange, but with a refresh it's fixed.
That sounds like cache and app cache. Are you still seeing the screen like that?
EdwinK
Re: machinon theme
Post by EdwinK » Tuesday 09 October 2018 20:18
Only when I return to it after some time, refreshing fixes it. I;m going to clear the appcache when I'm ready for today
remb0
Re: machinon theme
Post by remb0 » Friday 12 October 2018 17:10
when does the beta pushed to the master?
I see some nice commits ;)
EdddieN
Re: machinon theme
Post by EdddieN » Friday 12 October 2018 17:32
I use beta and it is pretty stable (for now), however there're a couple of issues with some browsers regarding tiles flex, @landaisbenj working hard to recode that part.
@landaisbenj and @DewGew had forked beta into further two branches (alphas?). I hope we could reach a stable milestone release soon as there're many new features planned, but best to close property stage 1.
I also like to say that without @landaisbenj and @DewGew involvement on this theme, this would not be possible - BIG thank you!
To check beta:
cd domoticz/www/styles
git clone https://github.com/EdddieN/machinon-domoticz_theme.git machinon-beta
cd machinon-beta
git checkout beta
heggink
Domoticz version: V4.9999
Re: machinon theme
Post by heggink » Friday 12 October 2018 17:35
I use the beta and an very happy with it. Wish I had the time to contribute...
Pi3, latest beta
RFXCOM, z-wave (AEOTEC, switches, temhum, pir, contacts),
Plugwise2py, P1 'smart'meter & solar panel
Alexa, Wifi Cams motion detection
ESP: relays, PIR & Temp/TempHum
Harmony hub, Nest
landaisbenj
Domoticz version: stable
Re: machinon theme
Post by landaisbenj » Friday 12 October 2018 20:30
Wish i had More Time to contribute too :(
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
EastXIII
Re: machinon theme
Post by EastXIII » Friday 12 October 2018 21:07
Very, very nice theme! Thank you for that!
Because i'm busy building my custom Dashticz V2 dash I found that I'm searching for the IDX numbers quite often. They can be found in "Devices" obviously, but the Aurora theme has the great advantage, at least for me, that the IDX is visible in the block itself.
Not within the favorits section of Domoticz, but in the specific tabs it is.
Is this something that could be implemented in this beauty? Off course only when I'm not the only one seeing this advantage.
landaisbenj
Re: machinon theme
Post by landaisbenj » Friday 12 October 2018 21:10
Yes i had think about this.. We must to open an issue to add this on our todo.
Platforme: Rpbi3b
poudenes
Domoticz version: 3.8993
Re: machinon theme
Post by poudenes » Saturday 13 October 2018 7:44
That is a good idea. I'll like it!
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
EdwinK
Re: machinon theme
Post by EdwinK » Saturday 13 October 2018 9:17
And nw, suddenly it works like it should.
heggink
Re: machinon theme
Post by heggink » Saturday 13 October 2018 9:17
It's a shame that so much in domoticz is dependent on the idx. One reason I really like dzvents. Replacing a device is a no maintenance event. Idx' really should be an internal thing.
Pi3, latest beta
Harmony hub, Nest
poudenes
Re: machinon theme
Post by poudenes » Saturday 13 October 2018 19:24
I have a global_data and give any IDX a name. When a device change and also IDX i only have to change it on the global_data and all my dzvents script are working normal without changing anything
heggink
Re: machinon theme
Post by heggink » Sunday 14 October 2018 10:01
I know but that doesn't work for things like dashticz and you still need to maintain global data. My point was more generic in a sense that the idx should have been an internal thing. Even blockly works with idx so if you swap a device, you need to update it...
Pi3, latest beta
Harmony hub, Nest
EdddieN
Re: machinon theme
Post by EdddieN » Monday 15 October 2018 11:42
Anyone that could help us make this happen?
https://github.com/EdddieN/machinon-dom ... issues/138
vamp
Re: machinon theme
Post by vamp » Thursday 18 October 2018 13:50
I use the latest beta, i think the font size is too big (or box sizes is too small)
