machinon theme
EdddieN
Target OS: Raspberry Pi
Domoticz version: 4.9700
Re: machinon theme
Post by EdddieN » Saturday 15 September 2018 12:21
EdwinK wrote:
Saturday 15 September 2018 9:38
Running on Mac El Capitan and used both chrome and safari browsers, both give the same problems. For now switched back to one of the standard themes, and no problems.
Already did clean appcache and the normal cache. I'll try the incognito method next.
Can you try this?
1.- Try the backup button
2.- on terminal, run top
3.- is your domoticz eating a lot of CPU?
I just tried on High Sierra and Chrome and it worked, that said, it took a while as my DB is quite big. For a moment I thought it was not working, until I run top and I could see it was working hard
11101101 - www.machinon.com
EdddieN
Re: machinon theme
Post by EdddieN » Saturday 15 September 2018 12:31
heggink wrote:
Saturday 15 September 2018 10:21
How are the settings saved? On Android, I can select dark and it sticks. On linux/chrome, I can select dark but next time I start chrome, I am back to the light settings. I do clear all my cache and cookies on exit though (click & clean). Tried to get click&clean to retain all info but it still won;t stick :-(.
I can imagine in a cookie? That is the only way to have different setups in different devices.
Just trie don mac with Chrome and Safari. Works fine.
Tried also on Ubuntu with Firefox, works fine too.
If you clear the cache it will probably reset your settings too. Failing that, you can always try to reset the theme itself before saving settings and see how it goes?
DewGew
Domoticz version: V4.9741
Re: machinon theme
Post by DewGew » Saturday 15 September 2018 15:33
Settings are stored in localStorage in your browser.
Raspberry Pi 2B - domoticz - Aeon Labs Z-Stick GEN5 - RFlink gateway
NanoPi NEO-air - domoticz - REGO6XX interface
Dashticz V2 - Homebridge
Holland
Domoticz version: Beta Ch
Re: machinon theme
Post by Holland » Saturday 15 September 2018 23:40
To everyone that is working on this project, fantastic job, I really like the theme.
Just a cosmetic issue I would like to bring forward.
Dashboard and other tabs resize when the refresh button is pressed. This is browser independent.
A picture makes it clear. As can be seen below, a refresh results in a
Switching tabs
Refresh page.JPG (165.05 KiB) Viewed 314 times
Switchs tabs.JPG (168.77 KiB) Viewed 314 times
EdddieN
Re: machinon theme
Post by EdddieN » Sunday 16 September 2018 10:46
Yes it is a known issue: https://github.com/EdddieN/machinon-dom ... /issues/31
If you can add those screens to the issue above on github it would be great.
Thanks for the feedback! :)
EdwinK
Re: machinon theme
Post by EdwinK » Sunday 16 September 2018 10:50
Can you try this?
As far as i can see with top, domoticz isn't using much cpu.
Running latest BETA on a Pi-3 | Toon Thermostat | RFxcom | Dashticz V2 |
EdddieN
Re: machinon theme
Post by EdddieN » Sunday 16 September 2018 12:02
Mmm... I think we need more feedback on a way to reproduce it. I can not reproduce the error, do you see anything odd under chrome inspector?
Holland
Re: machinon theme
Post by Holland » Sunday 16 September 2018 12:35
Will do!
poudenes
Domoticz version: 3.8993
Re: machinon theme
Post by poudenes » Sunday 16 September 2018 12:44
Hi ALl,
Maybe a idea ( i think its a good feature) to have a icon that indicates if a bulb have a Sub/Slave Devices.
I use Sub/Slave device option a lot. Would be nice to see a icon like a link icon so you see in the overview what bulbs are linked or not.
Something like this next to the diagram icon right down corner
Cheers,
Peter
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
EdwinK
Re: machinon theme
Post by EdwinK » Sunday 16 September 2018 18:48
Haven't been able to get online much today, but as far as I can see now, it must be a larger problem with Domoticz it self, as it is now also not working on other themes, and after some time, Domoticz goes off-line.
However, this is what I could find sofar:
[Deprecation] Application Cache is deprecated in non-secure contexts, and will be restricted to secure contexts in M69, around September 2018. Please consider migrating your application to HTTPS, and eventually shifting over to Service Workers. See https://goo.gl/rStTGz for more details.
:8080/#/Setup:1 Document was loaded from Application Cache with manifest http://192.168.0.11:8080/html5.appcache
:8080/#/Setup:1 Application Cache Checking event
jquery-3.3.1.min.js:2 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery-3.3.1.min.js:2
ajax @ jquery-3.3.1.min.js:2
(anonymous) @ custom.js:14
VM204:1 Uncaught SyntaxError: Unexpected token <
    at m (jquery-3.3.1.min.js:2)
    at Function.globalEval (jquery-3.3.1.min.js:2)
    at text script (jquery-3.3.1.min.js:2)
    at Ut (jquery-3.3.1.min.js:2)
    at k (jquery-3.3.1.min.js:2)
    at XMLHttpRequest.<anonymous> (jquery-3.3.1.min.js:2)
    at XMLHttpRequest.send (<anonymous>:1:781)
    at Object.send (jquery-3.3.1.min.js:2)
    at Function.ajax (jquery-3.3.1.min.js:2)
    at custom.js:14
m @ jquery-3.3.1.min.js:2
globalEval @ jquery-3.3.1.min.js:2
text script @ jquery-3.3.1.min.js:2
Ut @ jquery-3.3.1.min.js:2
k @ jquery-3.3.1.min.js:2
(anonymous) @ jquery-3.3.1.min.js:2
(anonymous) @ VM172:1
load (async)
VM206:1 Uncaught SyntaxError: Unexpected token <
    at custom.js:15
(anonymous) @ custom.js:15
load (async)
custom.js:44 Uncaught ReferenceError: locationHashChanged is not defined
    at custom.js:44
(anonymous) @ custom.js:44
:8080/#/Setup:1 Application Cache Error event: Manifest fetch failed (6) http://192.168.0.11:8080/html5.appcache
(index):142 [Deprecation] Application Cache is deprecated in non-secure contexts, and will be restricted to secure contexts in M69, around September 2018. Please consider migrating your application to HTTPS, and eventually shifting over to Service Workers. See https://goo.gl/rStTGz for more details.
(anonymous) @ (index):142
onloadwff.js:58 Uncaught (in promise) TypeError: Cannot read property 'querySelectorAll' of null
    at t.getFormInputs (onloadwff.js:58)
    at t.<anonymous> (onloadwff.js:58)
    at onloadwff.js:58
    at Object.next (onloadwff.js:58)
    at onloadwff.js:58
    at new Promise (<anonymous>)
    at Proxy.__awaiter (onloadwff.js:58)
    at t.detectForm (onloadwff.js:58)
    at onloadwff.js:58
    at onloadwff.js:58
t.getFormInputs @ onloadwff.js:58
(anonymous) @ onloadwff.js:58
__awaiter @ onloadwff.js:58
t.detectForm @ onloadwff.js:58
    at onloadwff.js:58
    at onloadwff.js:58
    at onloadwff.js:58
    at onloadwff.js:58
VM172:1 GET http://192.168.0.11:8080/json.htm?type=command&param=getconfig 0 ()
$rootScope.GetGlobalConfig @ app.js:978
(anonymous) @ app.js:1075
invoke @ angular.min.js:44
(anonymous) @ angular.min.js:46
r @ angular.min.js:8
gb @ angular.min.js:46
c @ angular.min.js:22
Uc @ angular.min.js:22
(anonymous) @ angularAMD.min.js:26
c @ jquery-3.3.1.min.js:2
setTimeout (async)
u @ jquery-3.3.1.min.js:2
add @ jquery-3.3.1.min.js:2
Deferred @ jquery-3.3.1.min.js:2
then @ jquery-3.3.1.min.js:2
w.fn.ready @ jquery-3.3.1.min.js:2
AngularAMD.bootstrap @ angularAMD.min.js:26
(anonymous) @ app.js:1243
execCb @ require.js:29
check @ require.js:18
(anonymous) @ require.js:23
(anonymous) @ require.js:8
v @ require.js:7
emit @ require.js:23
check @ require.js:19
enable @ require.js:23
init @ require.js:17
E @ require.js:14
completeLoad @ require.js:28
onScriptLoad @ require.js:29
load (async)
g.load @ require.js:34
load @ require.js:29
load @ require.js:18
(anonymous) @ require.js:17
v @ require.js:7
E @ require.js:14
load (async)
fetch @ require.js:17
enable @ require.js:27
v @ require.js:7
enable @ require.js:22
(anonymous) @ require.js:26
setTimeout (async)
g.nextTick @ require.js:32
j @ require.js:26
v @ require.js:7
E @ require.js:14
load (async)
v @ require.js:7
setTimeout (async)
j @ require.js:26
configure @ require.js:25
requirejs @ require.js:31
g.config @ require.js:31
(anonymous) @ main.js:1
VM172:1 GET http://192.168.0.11:8080/json.htm?type=command&param=getversion 0 ()
(anonymous) @ app.js:1076
setTimeout (async)
v @ require.js:7
E @ require.js:14
load (async)
v @ require.js:7
E @ require.js:14
load (async)
v @ require.js:7
setTimeout (async)
j @ require.js:26
v @ require.js:7
E @ require.js:14
load (async)
v @ require.js:7
setTimeout (async)
j @ require.js:26
VM172:1 GET http://192.168.0.11:8080/json.htm?type=command&param=getauth 0 ()
(anonymous) @ app.js:1108
setTimeout (async)
v @ require.js:7
E @ require.js:14
load (async)
v @ require.js:7
E @ require.js:14
load (async)
v @ require.js:7
setTimeout (async)
j @ require.js:26
v @ require.js:7
E @ require.js:14
load (async)
v @ require.js:7
setTimeout (async)
j @ require.js:26
EdddieN
Re: machinon theme
Post by EdddieN » Monday 17 September 2018 16:29
uh! that goes way beyond my knowledge... hopefully someone else can help
EdwinK
Re: machinon theme
Post by EdwinK » Monday 17 September 2018 22:43
Will find out, some day, some how
EdddieN
Re: machinon theme
Post by EdddieN » Wednesday 19 September 2018 23:21
I have uploaded a few files to zeplin, still working with the white theme mostly. I want to make sure all is perfect before focusing on the dark version.
The settings page looks nice, but still sometimes takes me a a few seconds to figure out where I am. Would a screen like this help?
Screen Shot 2018-09-19 at 22.17.56.png (130.33 KiB) Viewed 126 times
Holland
Re: machinon theme
Post by Holland » Wednesday 19 September 2018 23:56
Much better!!
bueno79
Re: machinon theme
Post by bueno79 » Thursday 20 September 2018 8:57
hi,
really nice. It is possible to group device in your theme ? And do you manage camera in dashboard ?
best regards
Bueno
EdddieN
Re: machinon theme
Post by EdddieN » Thursday 20 September 2018 9:50
Re camera, would like to
Re group, what do you mean?
bueno79
Re: machinon theme
Post by bueno79 » Thursday 20 September 2018 10:06
hi,
the possibility to display camera on the dashboard. For the grouping :
if you take air cooling system, to manage a such device you need :
- mode selector (on, off, hot, cold, dry,..)
- flow selector (auto, night, power1, power2,power3, ...)
- temp selector
mode and flow selector are in "switch" section but Temp selector is in "utility" section...it is very annoying. So if we can merge multiple device in one place or one big control it will be awesome.
Another exemple is power for plug..we have multiple in utility. Could be awesome to merge different in one. Aurora theme started to work on this point but it was not enough
Personnaly I think Domoticz is a ver very good product but the current frontend is not good enough.
best regards
EdddieN
Re: machinon theme
Post by EdddieN » Thursday 20 September 2018 11:15
I see, it looks more like a front end app on itself than a theme.
Aurora does it on the dashboard correct?
bueno79
Re: machinon theme
Post by bueno79 » Thursday 20 September 2018 12:52
yes it is.
landaisbenj
Domoticz version: stable
Re: machinon theme
Post by landaisbenj » Thursday 20 September 2018 12:57
My work re open my domoticz !!! :o :o :P :P
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
