P1 Electricity Meter values not logged correctly.
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Templar
Domoticz version: V4.9700
Post by Templar » Saturday 30 June 2018 12:51
Version: 4.9700
Platform: DSM
Plugin/Hardware: Toon
Description:
My Toon P1 electricity meter values are not logged correctly. About every 25 seconds it logs 0 Wh. Domoticz is conneccted with a Toon /smart meter combination. I also had this problem with older Domoticz versions. Before that I used a Youless meter and that gave the same problems.
FYI: Between 10:00 and 12:30 I deleted some zero values.
P1 Electricity Meter usage
2018-06-29 12:45:00	0	0
2018-06-29 12:50:00	0	24
2018-06-29 12:55:00	0	180
2018-06-29 13:00:00	0	0
2018-06-29 13:05:00	0	84
2018-06-29 13:10:00	0	156
2018-06-29 13:15:00	0	156
2018-06-29 13:20:00	0	144
2018-06-29 13:25:00	0	0
2018-06-29 13:30:00	0	156
2018-06-29 13:35:00	0	144
2018-06-29 13:40:00	0	156
2018-06-29 13:45:00	0	0
2018-06-29 13:50:00	0	144
2018-06-29 13:55:00	0	168
2018-06-29 14:00:00	0	168
2018-06-29 14:05:00	0	0
2018-06-29 14:10:00	0	180
2018-06-29 14:15:00	0	276
2018-06-29 14:20:00	0	276
2018-06-29 14:25:00	0	0
2018-06-29 14:30:00	0	252
2018-06-29 14:35:00	0	264
2018-06-29 14:40:00	0	240
2018-06-29 14:45:00	0	0
2018-06-29 14:50:00	0	204
2018-06-29 14:55:00	0	156
2018-06-29 15:00:00	0	168
2018-06-29 15:05:00	0	96
2018-06-29 15:10:00	0	0
2018-06-29 15:15:00	0	84
2018-06-29 15:20:00	0	84
2018-06-29 15:25:00	0	72
2018-06-29 15:30:00	0	0
2018-06-29 15:35:00	0	84
2018-06-29 15:40:00	0	96
2018-06-29 15:45:00	0	168
2018-06-29 15:50:00	0	0
2018-06-29 15:55:00	0	180
2018-06-29 16:00:00	0	192
2018-06-29 16:05:00	0	288
2018-06-29 16:10:00	0	0
2018-06-29 16:15:00	0	288
2018-06-29 16:20:00	0	288
2018-06-29 16:25:00	0	276
2018-06-29 16:30:00	0	0
2018-06-29 16:35:00	0	276
2018-06-29 16:40:00	0	192
2018-06-29 16:45:00	0	192
2018-06-29 16:50:00	0	176
2018-06-29 16:55:00	0	0
2018-06-29 17:00:00	0	192
2018-06-29 17:05:00	0	204
2018-06-29 17:10:00	0	192
2018-06-29 17:15:00	0	0
2018-06-29 17:20:00	0	204
2018-06-29 17:25:00	0	192
2018-06-29 17:30:00	0	204
2018-06-29 17:35:00	0	0
2018-06-29 17:40:00	0	180
2018-06-29 17:45:00	0	192
2018-06-29 17:50:00	0	240
2018-06-29 17:55:00	0	0
2018-06-29 18:00:00	0	264
2018-06-29 18:05:00	0	252
2018-06-29 18:10:00	0	264
2018-06-29 18:15:00	0	252
2018-06-29 18:20:00	0	0
2018-06-29 18:25:00	0	216
2018-06-29 18:30:00	0	156
2018-06-29 18:35:00	0	156
2018-06-29 18:40:00	0	0
2018-06-29 18:45:00	0	144
2018-06-29 18:50:00	0	168
2018-06-29 18:55:00	0	156
2018-06-29 19:00:00	0	0
2018-06-29 19:05:00	0	168
2018-06-29 19:10:00	0	156
2018-06-29 19:15:00	0	144
2018-06-29 19:20:00	0	0
2018-06-29 19:25:00	0	168
2018-06-29 19:30:00	0	156
2018-06-29 19:35:00	0	144
2018-06-29 19:40:00	0	0
2018-06-29 19:45:00	0	168
2018-06-29 19:50:00	0	240
2018-06-29 19:55:00	0	264
2018-06-29 20:00:00	0	264
2018-06-29 20:05:00	0	0
2018-06-29 20:10:00	0	252
2018-06-29 20:15:00	0	276
2018-06-29 20:20:00	0	228
2018-06-29 20:25:00	0	0
2018-06-29 20:30:00	0	204
2018-06-29 20:35:00	0	192
2018-06-29 20:40:00	0	204
2018-06-29 20:45:00	0	0
2018-06-29 20:50:00	0	192
2018-06-29 20:55:00	0	192
2018-06-29 21:00:00	0	204
2018-06-29 21:05:00	0	0
2018-06-29 21:10:00	0	192
2018-06-29 21:15:00	0	192
2018-06-29 21:20:00	0	192
2018-06-29 21:25:00	0	0
2018-06-29 21:30:00	0	192
2018-06-29 21:35:00	0	192
2018-06-29 21:40:00	0	192
2018-06-29 21:45:00	0	288
2018-06-29 21:50:00	0	0
2018-06-29 21:55:00	0	288
2018-06-29 22:00:00	0	288
2018-06-29 22:05:00	0	300
2018-06-29 22:10:00	0	0
2018-06-29 22:15:00	0	264
2018-06-29 22:20:00	0	240
2018-06-29 22:25:00	0	192
2018-06-29 22:30:00	0	0
2018-06-29 22:35:00	0	192
2018-06-29 22:40:00	0	192
2018-06-29 22:45:00	0	204
2018-06-29 22:50:00	0	0
2018-06-29 22:55:00	0	192
2018-06-29 23:00:00	0	192
2018-06-29 23:05:00	96	108
(edited hardware)
Synology DS114 NAS Domoticz package
gordonb3
Domoticz version: Custom
Re: P1 Electricity Meter values not logged correctly.
Post by gordonb3 » Saturday 30 June 2018 15:58
Those would be minutes. Also, this is not P1 but Toon. It works better if you correctly name the hardware type you are using. Quick glampse at the Toon source learns that this hardware does in fact only get the data once every 5 minutes and apparently that 0 value is either what Toon reports or you should have some error in your log saying that it can't connect.
Also I'm not really sure what those numbers are supposed to represent. They seem extremely low compared to what I see in the P1 reports on my own system. With these numbers you should be somewhere at 2-3kWh per day?
Templar
Post by Templar » Saturday 30 June 2018 17:17
Well, the Toon displays the data correctly. But Domoticz does log errors like this:
2018-06-30 16:57:33.451 Error: ToonThermostat: retrieveToonState request not successful, restarting..!
2018-06-30 17:04:06.537 Error: ToonThermostat: retrieveToonState request not successful, restarting..!
2018-06-30 17:10:39.821 Error: ToonThermostat: retrieveToonState request not successful, restarting..!
Those numbers are Watts, it's the data table of the graph.
gordonb3
Post by gordonb3 » Saturday 30 June 2018 18:29
Well, that explains your issue then.
Watts? That doesn't make sense. You're looking at 5-minute values, so you would want to be seeing what you used during that 5 minutes rather than a timeless snapshot of the exact moment when the numbers were recorded.
Templar
Post by Templar » Saturday 14 July 2018 12:10
Is there any reason why this error persists? Could it be Toon Wi-Fi problems or could it be Domoticz/Synology related?
FYI: Toon uses the latest firmware (4.16.8) and is not rooted.
