Unable to control scene using json in HA Bridge
foffen
Target OS: Raspberry Pi
Post by foffen » Saturday 30 June 2018 1:55
Added a scene to HA bridge but it fals tesing, i have imported it as domotics device so it's autoconfigured and all other switches works fine but this one:
URL
RESULT
"status" : "ERR"
I have verified that it is the correct idx and if i simply try to substitute with another idx it works. Also, the scene works fine from within domoticz web interface.
When i test the switch in HA bridge i get error:
Request Error, Please look in your habridge log: error {"type":"6","address":"/lights/12","description":"Error on calling url to change device state","method_name":"/lights/12state"}
Domoticz is runing 4.9700 on a raspberry pi3 with razberry card and RFLINK. most sub components are fairly up to date.
I cannot wrap my head around why it wont bite on this scene alone. :?
Re: Unable to control scene using json in HA Bridge
Post by waaren » Saturday 30 June 2018 12:00
URL
http://10.10.10.31:8080/json.htm?type=c ... itchcmd=On
What is the result if you enter this URL in your browser ?
Should it not be http://10.10.10.31:8080/json.htm?type=c ... itchcmd=On
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
1970sITman
Post by 1970sITman » Monday 02 July 2018 15:25
I've got the same problem but before I had to rebuild my Pi completely and reinstall everyting, it used to work!
If i copy/paste the control line from Habridge into a browser, the scene/group command does NOT work but just by changing the index number to a single light switch , it works, both via Habridge and direct from a browser.
Is all that's usually necessary is to change the index number?
4 pi(master+RFXtrx433 and 3 slaves+PiFace)
HE, BBSB, Lightwave, Micromark, Retrotouch & LIVOLO sockets, door switches, PIRs & Dimmers
EVE on iPad for Voice
Weather sensors
OWL CM160
eQ-3 MAX! Heating Controls (10 therms, 8 valves, 2 relays)
Post by waaren » Monday 02 July 2018 15:39
the json command to activate a scene is:
http://domoticzIP:domoticzPort/json.htm?type=command&param=switchscene&idx=IDX&switchcmd=On
for single lights/ switch, the command is:
http://domoticzIP:domoticzPort/json.htm?type=command&param=switchlight&idx=IDX&switchcmd=On
these are the type of JSON / API calls HABridge use to make something happen in domoticz.
1970sITman
Post by 1970sITman » Wednesday 04 July 2018 23:30
Excellent, Thanks. That's what was wrong. The Domoticz device 'auto-build' within HABridge is not creating the correct syntax.
It is putting ...................command&param=switchlight&idx=12&switchcmd=On
as opposed to ...............command&param=switchscene&idx=12&switchcmd=On
Once I edited the line in question, everything works.
Weather sensors
OWL CM160
Post by waaren » Wednesday 04 July 2018 23:36
Good that it worked for you. In my version of the HABridge (5.2.1) the build command for scenes and groups generates the right JSON command. What version are you on ?
