Smart home dashboard app is now compatible with Domoticz - needs feedback
igor
Post by igor » Friday 29 June 2018 12:05
Project Rotini is a beta of a smart home dashboard that allows you to connect and control several popular smart home platforms. We just recently added experimental Domoticz support that supports main components such as switches, light, scenes and more. Integration is going to improve in the following releases.
We are looking for a feedback from users in the community.
Please try it out and let us know what you think.
Play Store: https://play.google.com/store/apps/deta ... otini.beta
App Community: https://community.projectrotini.com
Take care,
Igor
Bigted
Target OS: Raspberry Pi
Re: Smart home dashboard app is now compatible with Domoticz - needs feedback
Post by Bigted » Saturday 30 June 2018 17:50
Only sees Z-wave devices
Doesn't switch any Z-wave devices
Temperatures only work if you select gauge
igor
Post by igor » Saturday 30 June 2018 18:16
Thanks for checking it out!
Can you give some more details which temperature devices do you use? Which widgets you want to use for temperature?
Number of supported devices will be extending with new releases.
Alcloud
Post by Alcloud » Wednesday 04 July 2018 21:47
In the last app version dimmer doesn't work and i can't add any domoticz switches (only scenes).
igor
Post by igor » Wednesday 04 July 2018 21:59
Can you provide more details, since there are no reports of similar issues from other users, it might be something more specific:
- exact app version (shown in support section of the app)
- android device and os version
- domoticz version
- domoticz device type, variant, etc. (if possible)
Alcloud
Post by Alcloud » Wednesday 04 July 2018 22:34
- domoticz version
- 1.0 Beta 4.2 (1220)
- Sony xperia Z5, Android 7.1.1
- 4.9741
- Light: Domoticz type - "Colour Switch" (I use MiLight RGBW). Like a switch works perfect, but not like dim.
And the app doesn't see any domoticz switches from type "Lighting 1" (manual created switches)
Thank you.
igor
Post by igor » Wednesday 04 July 2018 23:35
Just to make sure I understood correctly, was it working for you in the previous version, or "1.0 Beta 4.2" is the first version you tried?
Manual switches will be supported soon.
Alcloud
Post by Alcloud » Wednesday 04 July 2018 23:54
Yes, in the previous version it was ok( I tested it yesterday).
igor
Post by igor » Thursday 05 July 2018 0:05
There were no changes in related to Domoticz integration or dimmers in this release, so it is not clear why it is not working at the moment.
Will update after we do some additional investigation.
Thanks for reporting a bug.
codesnipper
Post by codesnipper » Friday 03 August 2018 16:03
Very promising app. Simple but powerfull.
In my Domoticz i can only see temperatures as gauge , no manual switches, no weather (DarkSky, netatmo).
DAVIZINHO
Post by DAVIZINHO » Sunday 05 August 2018 19:36
hello
i want to try but the connection test fail:
"unable to verify ssl certificate"
any idea?
bramski
Post by bramski » Sunday 05 August 2018 20:27
Very cool app and idea. Got my domoticz instance connected.
Did some quick setup and ran into some issues.
- Could not add my temperature sensors which are combined sensors temp/hum/bar
- Cannot find any of my shutters/blinds when I select shutters type.
Improvements.
- Add widget for rgbw lights, including color picker
- When you add a new widget after binding the device set the label to domoticz device name by default. Now I have to define all labels manual
MiloshCZ
Post by MiloshCZ » Monday 13 August 2018 12:26
Nice app, I like simple design, but:
  • No temperature + humidity sensors
  • No utility devices (water, electricity, percentage...)
  • No Rain sensor (rainrate, total rain)
