Request: Lua script can read settings
jagroeneveld
Target OS: Raspberry Pi
Post by jagroeneveld » Tuesday 26 June 2018 18:40
I'd like to be able to read the settings using lua. Especially the location settings are of interest to me.
I know I could use json, but since I protected my Domotic, I have to use a userid/password in the script which I don't like for some reason.
Nice to have:
location = settings['location'] (as a line in a lua script)
from https://www.domoticz.com/wiki/Lua_-_json.lua (with change to use wget instead of curl):
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
--json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
read = os.execute('wget '..tempfilename..' http://localhost:<port>/json.htm?type=settings')
file = io.open(tempfilename, "r")
settings = file:read('*all')
file.close()
location = json:decode(settings)
lat = jsonLocation.current_observation.display_location.latitude
lon = jsonLocation.current_observation.display_location.longitude
Re: Request: Lua script can read settings
Post by waaren » Tuesday 26 June 2018 20:49
Not sure if you do not want password less access from local system either. That would be required for this dzVents / Lua script.
SETUP -> SETTINGS -> LOCAL NETWORKS (NO USERNAME/PASSWORD): 127.0.0.*
I use the approach as in this script in various other dzVents scripts and store the Latitude / Longitude in (Global) persistent data variables so that I only have to call the openURL once.
--[[ getLocation.lua
    on = {      devices         =   { "locationTrigger" },            -- Just a trigger switch to kick off script
                httpResponses   =   { "LocationResponse" }
    execute = function(dz, trigger)
        if trigger.isTimer or trigger.isDevice then
                dz.openURL({
                        url = dz.settings['Domoticz url'] ..  "/json.htm?type=settings",
                        method = "GET",
                        callback = "LocationResponse" })
            print("Latitude:  " ..trigger.json.Location.Latitude)
            print("Longitude: " ..trigger.json.Location.Longitude)
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
