Domoticz starting as root, so no scripts run!
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
doh
Post by doh » Monday 25 June 2018 18:02
I'm running Domoticz (v4) on a Raspberry Pi - "Raspbian GNU/Linux 9 (stretch)"
Scripts are not firing, and I've managed to debug this down to the fact that the domoticz.sh service is starting as root - despite the fact that domoticz.sh says to do otherwise:
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
DESC="Domoticz Home Automation System"
NAME=domoticz
USERNAME=pi
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
DAEMON=/home/pi/domoticz/$NAME
DAEMON_ARGS="-daemon"
#DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
#DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
DAEMON_ARGS="$DAEMON_ARGS -loglevel 1 -syslog local1"
root@domoticz:/etc/init.d# service domoticz.sh status
● domoticz.service - LSB: Home Automation System
   Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
   Active: active (running) since Mon 2018-06-25 16:57:07 BST; 4min 28s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 10650 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
  Process: 10708 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/domoticz.service
           └─10715 /home/pi/domoticz/domoticz -daemon -www 8080 -loglevel 1 -syslog local1
root@domoticz:/etc/init.d# ps -ef | grep domo
avahi      321     1  0 16:14 ?        00:00:00 avahi-daemon: running [domoticz.local]
root     10715     1  2 16:57 ?        00:00:06 /home/pi/domoticz/domoticz -daemon -www 8080 -loglevel 1 -syslog local1
root     11851  6023  0 17:02 pts/0    00:00:00 grep domo
Why won't it start as Pi instead of root, and how can I fix this so my scripts start working again?
SweetPants
Domoticz version: V4.10276
Re: Domoticz starting as root, so no scripts run!
Post by SweetPants » Monday 25 June 2018 18:28
As far as I know domoticz always has run as root. Try changing your script permissions like chmod 755 <your script>
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
doh
Post by doh » Monday 25 June 2018 18:53
Tried that and it makes no difference.
If I login as "pi" interactively and run /home/pi/domoticz/domoticz from the command prompt it starts fine and all the LUA scripts execute.
If I run it using the service, where it starts as root, it doesn't.
I've seen another post on here mention that when running as root it doesn't know where to find the LUA scripts, but that was on Ubuntu using service definitions rather than the domoticz.sh scripts. I can't figure out how to get this working properly on the Pi though.
It does look, to me, like it's changed recently - perhaps as part of the upgrade to v4?
dgilbert2
Target OS: Raspberry Pi
Domoticz version: 4.9728
Post by dgilbert2 » Monday 25 June 2018 21:16
Just a thought, when you upgraded to version 4, did you copy the scripts from a backup? They may have lost the execute flag?
doh
Post by doh » Monday 25 June 2018 21:38
No - they were still there from before the upgrade.
And, anyway, if I run domoticz interactively under the Pi user then everything works ok...
doh
Post by doh » Tuesday 26 June 2018 9:31
Anyone running Domoticz on a Pi, preferably as the Pi user, that could share how their service definition with me?
Sipowitz
Post by Sipowitz » Saturday 30 June 2018 16:18
I posted a topic a while back viewtopic.php?f=6&t=23753 because I could not get my scripts to run. I have tried starting domoticz manually as user 'pi' and my scripts now run so I am experiencing the same problem as you. Does anyone know how to run Domoticz as user 'pi'?
jaisonshetty
Post by jaisonshetty » Friday 13 July 2018 16:39
hello,
If you add a third slash you must specify the full path:
CODE: SELECT ALL
script:///home/pi/domoticz/scripts/skyhd_pause.sh
Add a simple logline to your script, something like:
CODE: SELECT ALL
#!/bin/bash
NOW=$(date +"%Y-%m-%d")
LOGFILE=/home/pi/sky-remote.$NOW.log
echo $(date +"%Y-%m-%d %H:%M:%S") sky-remote pause | tee -a $LOGFILE
sky-remote-cli 192.168.0.109 pause &
That should create a logfile (every day a new file) and add the timestamp of execution to it.
Personnaly I would set the command as an option in the command line:
CODE: SELECT ALL
#!/bin/bash
COMMAND="$1"
echo $(date +"%Y-%m-%d %H:%M:%S") sky-remote $COMMAND | tee -a $LOGFILE
sky-remote-cli 192.168.0.109 $COMMAND &
And then use this in domoticz:
CODE: SELECT ALL
script:///home/pi/domoticz/scripts/skyhd_pause.sh pause
That way you can use one script for other commands to, I assume you have other commands to sent as well?
chinmoypborah
Post by chinmoypborah » Friday 23 November 2018 9:09
Tutuapp https://kingrootapkz.com https://get-tubemate.in https://appsapkapp.com
