Check device online stops working after Domoticz V4.9700 update
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Meppel8
Target OS: Raspberry Pi
Domoticz version: V3.5877
Post by Meppel8 » Sunday 24 June 2018 12:26
Dear all,
Today I have updated my Domoticz to version V4.9700 ona a PI3 with success. Thanks for all the hard word to the developers.
Everything is running stable only my presence detection script is giving errors, like:
- import urllib2 not avaliable
and this error:
2018-06-24 12:16:25.858 Error: EventSystem: Failed to execute python event script "/home/pi/domoticz/scripts/python/check_device_online.py"
  2018-06-24 12:16:25.858 Error: EventSystem: File "/home/pi/domoticz/scripts/python/check_device_online.py", line 68
  2018-06-24 12:16:25.858 Error: EventSystem: print datetime.datetime.now().strftime("%H:%M:%S") + "- pid file exists"
  2018-06-24 12:16:25.858 Error: EventSystem: ^
  2018-06-24 12:16:25.858 Error: EventSystem: SyntaxError: invalid syntax
This is the script I use:
#   !/usr/bin/python
#   Title: check_device_online.py
#   Author: Chopper_Rob
#   Date: 25-02-2015
#   Info: Checks the presence of the given device on the network and reports back to domoticz
#   URL : https://www.chopperrob.nl/domoticz/5-report-devices-online-status-to-domoticz
#   Version : 1.6.2
import sys
import datetime
import time
import os
import subprocess
import urllib2
import json
import base64
# Settings for the domoticz server
domoticzserver ="192.168.178.112:8080"
domoticzusername = "pi"
domoticzpassword = "raspberry"
domoticzpasscode = "Niet aanzitten"
# If enabled. The script will log to the file _.log
# Logging to file only happens after the check for other instances, before that it only prints to screen.
log_to_file = False
# The script supports two types to check if another instance of the script is running.
# One will use the ps command, but this does not work on all machine (Synology has problems)
# The other option is to create a pid file named _.pid. The script will update the timestamp
# every interval. If a new instance of the script spawns it will check the age of the pid file.
# If the file doesn't exist or it is older then 3 * Interval it will keep running, otherwise is stops.
# Please chose the option you want to use "ps" or "pid", if this option is kept empty it will not check and just run.
check_for_instances = "pid"
# DO NOT CHANGE BEYOND THIS LINE
if len(sys.argv) != 5 :
  print ("Not enough parameters. Needs %Host %Switchid %Interval %Cooldownperiod.")
  sys.exit(0)
device=sys.argv[1]
switchid=sys.argv[2]
interval=sys.argv[3]
cooldownperiod=sys.argv[4]
previousstate=-1
lastsuccess=datetime.datetime.now()
lastreported=-1
base64string = base64.encodestring('%s:%s' % (domoticzusername, domoticzpassword)).replace('\n', '')
domoticzurl = 'http://'+domoticzserver+'/json.htm?type=devices&filter=all&used=true&order=Name'
if check_for_instances.lower() == "pid":
  pidfile = sys.argv[0] + '_' + sys.argv[1] + '.pid'
  if os.path.isfile( pidfile ):
    if (time.time() - os.path.getmtime(pidfile)) < (float(interval) * 3):
      print datetime.datetime.now().strftime("%H:%M:%S") + "- script seems to be still running, exiting"
      print datetime.datetime.now().strftime("%H:%M:%S") + "- If this is not correct, please delete file " + pidfile
      sys.exit(0)
    else:
      print datetime.datetime.now().strftime("%H:%M:%S") + "- Seems to be an old file, ignoring."
  else:
    open(pidfile, 'w').close()
if check_for_instances.lower() == "ps":
  if int(subprocess.check_output('ps x | grep \'' + sys.argv[0] + ' ' + sys.argv[1] + '\' | grep -cv grep', shell=True)) > 2 :
    print (datetime.datetime.now().strftime("%H:%M:%S") + "- script already running. exiting.")
    sys.exit(0)
def log(message):
  print message
  if log_to_file == True:
    logfile = open(sys.argv[0] + '_' + sys.argv[1] + '.log', "a")
    logfile.write(message + "\n")
    logfile.close()
def domoticzstatus ():
  json_object = json.loads(domoticzrequest(domoticzurl))
  status = 0
  switchfound = False
  if json_object["status"] == "OK":
    for i, v in enumerate(json_object["result"]):
      if json_object["result"][i]["idx"] == switchid:
        switchfound = True
        print (datetime.datetime.now().strftime("%H:%M:%S") + "- Switch ID found. Switch ID = " + switchid)
        if json_object["result"][i]["Status"] == "On":
          status = 1
        if json_object["result"][i]["Status"] == "Off":
          status = 0
  if switchfound == False: print (datetime.datetime.now().strftime("%H:%M:%S") + "- Error. Could not find switch idx in Domoticz response. Defaulting to switch off.")
  return status
def domoticzrequest (url):
  request = urllib2.Request(url)
  request.add_header("Authorization", "Basic %s" % base64string)
  response = urllib2.urlopen(request)
  return response.read()
log (datetime.datetime.now().strftime("%H:%M:%S") + "- script started.")
lastreported = domoticzstatus()
if lastreported == 1 :
  log (datetime.datetime.now().strftime("%H:%M:%S") + "- according to domoticz, " + device + " is online")
if lastreported == 0 :
  log (datetime.datetime.now().strftime("%H:%M:%S") + "- according to domoticz, " + device + " is offline")
while 1==1:
  # currentstate = subprocess.call('ping -q -c1 -W 1 '+ device + ' > /dev/null', shell=True)
  # currentstate = subprocess.call('sudo arping -q -c1 -W 1 '+ device + ' > /dev/null', shell=True)
  currentstate = subprocess.call('sudo ping -q -c1 -W 1 '+ device + ' > /dev/null', shell=True)
  if currentstate == 0 : lastsuccess=datetime.datetime.now()
  if currentstate == 0 and currentstate != previousstate and lastreported == 1 :
    log (datetime.datetime.now().strftime("%H:%M:%S") + "- " + device + " online, no need to tell domoticz")
  if currentstate == 0 and currentstate != previousstate and lastreported != 1 :
    if domoticzstatus() == 0 :
      log (datetime.datetime.now().strftime("%H:%M:%S") + "- " + device + " online, tell domoticz it's back")
      print (datetime.datetime.now().strftime("%H:%M:%S") + "- Send to Domoticz -> ON -> " + "http://" + domoticzserver + "/json.htm?type=command&param=switchlight&idx=" + switchid + "&switchcmd=On&level=0")
    # domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=switchlight&idx=" + switchid + "&switchcmd=On&level=0"  + "&passcode=" + domoticzpasscode)  --> er gaat nog wat mis met de bescherm code van en switch
      domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=switchlight&idx=" + switchid + "&switchcmd=On&level=0")
    else:
      log (datetime.datetime.now().strftime("%H:%M:%S") + "- " + device + " online, but domoticz already knew")
    lastreported=1
  if currentstate == 1 and currentstate != previousstate :
    log (datetime.datetime.now().strftime("%H:%M:%S") + "- " + device + " offline, waiting for it to come back")
  if currentstate == 1 and (datetime.datetime.now()-lastsuccess).total_seconds() > float(cooldownperiod) and lastreported != 0 :
    if domoticzstatus() == 1 :
      log (datetime.datetime.now().strftime("%H:%M:%S") + "- " + device + " offline, tell domoticz it's gone")
      print (datetime.datetime.now().strftime("%H:%M:%S") + "- Send to Domoticz -> OFF -> "+ "http://" + domoticzserver + "/json.htm?type=command&param=switchlight&idx=" + switchid + "&switchcmd=Off&level=0")
    # domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=switchlight&idx=" + switchid + "&switchcmd=Off&level=0" + "&passcode=" + domoticzpasscode)  --> er gaat nog wat mis met de bescherm code van en switch
      domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=switchlight&idx=" + switchid + "&switchcmd=Off&level=0")
    else:
      log (datetime.datetime.now().strftime("%H:%M:%S") + "- " + device + " offline, but domoticz already knew")
    lastreported=0
  time.sleep (float(interval))
  previousstate=currentstate
  if check_for_instances.lower() == "pid": open(pidfile, 'w').close()
Is Domoticz V4.9700 using an newer version of Python?
Someone knows a solution?
Thanks for your help.
Greeting Rene
SweetPants
Domoticz version: V4.9701
Re: Check device online stops working after Domoticz V4.9700 update
Post by SweetPants » Sunday 24 June 2018 13:34
Did you only update domoticz? Have you tried a re-boot? Looks like the script is already running
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
Meppel8
Post by Meppel8 » Monday 25 June 2018 7:08
Yes, I only updated Domoticz to the new stable version V4.9700 and reboot several times. Also started python update manual, but got the message: already the latest version.
And yes the script in running, but not correctly. Some line give a error . When I correct the print lines with ( and ) then there comes the Urllib2 error. I see a difference in this library between Python en Python version 3.
Could that be the problem? The Urllib2 is used for URL to access the log/status file for each GSM.
Thanks for helping.
mrohner
Domoticz version: 4.9700
Post by mrohner » Sunday 08 July 2018 14:18
Same error here. When I upgraded to V4.9700 I first got message:
EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
As I did have python 3.5. installed already, I followed some hints given in this forum and installed
libpython3.5-dev.
That made the above message disappear but the script, which perfectly ran before, shows:
2018-07-08 13:54:11.097 Error: EventSystem: Failed to execute python event script "/home/domoticz/domoticz/scripts/python/check_device_online.py"
2018-07-08 13:54:11.097 Error: EventSystem: File "/home/domoticz/domoticz/scripts/python/check_device_online.py", line 56
2018-07-08 13:54:11.097 Error: EventSystem: print datetime.datetime.now().strftime("%H:%M:%S") + "- pid file exists"
2018-07-08 13:54:11.097 Error: EventSystem: ^
2018-07-08 13:54:11.097 Error: EventSystem: SyntaxError: invalid syntax
SjoerdNLD
Post by SjoerdNLD » Tuesday 10 July 2018 23:13
Got the same, it is due version 3 of python;
Modified to work as before:
#!/usr/bin/python
#   Date: 25-02-2015
#   Version : 1.6.2.1 modified by SjoerdNLD for python 3
import sys
import datetime
import time
import os
import subprocess
import urllib.request
import json
import base64
domoticzserver="127.0.0.1:8080/domoticz"
domoticzpasscode = "Black"
log_to_file = False
  sys.exit(0)
device=sys.argv[1]
previousstate=-1
lastreported=-1
    print (datetime.datetime.now().strftime("%H:%M:%S") + "- pid file exists")
      print (datetime.datetime.now().strftime("%H:%M:%S") + "- script seems to be still running, exiting")
      print (datetime.datetime.now().strftime("%H:%M:%S") + "- If this is not correct, please delete file " + pidfile)
      sys.exit(0)
    else:
      print (datetime.datetime.now().strftime("%H:%M:%S") + "- Seems to be an old file, ignoring.")
  else:
    sys.exit(0)
def log(message):
  print (message)
    logfile.close()
  status = 0
  switchfound = False
        switchfound = True
          status = 1
          status = 0
  return status
  request = urllib.request.Request(url)
  response = urllib.request.urlopen(request)
while 1==1:
  currentstate = subprocess.call('sudo arping -q -c10 -w500000 '+ device + ' > /dev/null', shell=True)
    else:
    lastreported=1
    else:
    lastreported=0
Meppel8
Post by Meppel8 » Thursday 12 July 2018 20:33
Hello Sjoerd,
Thanks for the modified script, my first impression was right that it had something to do with the Python library. I have installed it on domotics and I have the following error:
Line 27: import urllib.request
ImportError: No module named request
Did't you have that error? Is there something wrong with my python library after the update to V4.9700.
Thanks for your help I have spend many hours already.
Best regard Rene
Users browsing this forum: No registered users and 10 guests
