Domoticz version 4.9700 released (Stable)
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
gerardwr
Re: Domoticz version 4.9700 released (Stable)
Post by gerardwr » Friday 10 August 2018 21:06
Plantje wrote:
Friday 10 August 2018 13:22
What sort of updates are those? I mean: what are you doing that uses these HTTP paths?
I use it to link buttons from a selector switch to a device with an HTTP API. Have a look here:
viewtopic.php?f=28&t=16698
Plantje
Post by Plantje » Friday 10 August 2018 21:35
Cool! Nice stuff
Hobbybob
Target OS: Raspberry Pi
Domoticz version: Stable
Post by Hobbybob » Saturday 11 August 2018 17:56
I have a small problem after updating from the previous stable-release to this one. My daily water-usage was previously shown in liters, but it is now shown in m3.
Is there anywhere I can change that, because liters are much more descriptive in my opinion.
Underscore
Domoticz version: v3.8153
Post by Underscore » Sunday 12 August 2018 13:12
hansies wrote:
Thursday 09 August 2018 17:29
I want to use Telegram notifications in v4.9. So not via http, but the special build Telegram notifications.
Unfortunately I don't receive notifications when I click the test button. Anyone else who is successful with it?
In API key I fill in my bot API:
000000000:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
In chat-id I fill in my id belonging to my personal account.
I've got the same problem; entered all correct details under Settings - Notifications - Telegram.
When I hit the "Test" button, the message is not being received within Telegram. Instead I see the following log entries:
2018-08-11 14:52:32.621 Status: Notification: Domoticz test
2018-08-11 14:52:33.876 Notification sent (telegram) => Failed
2018-08-11 14:52:33.922 Active notification Subsystems: email, telegram (2/13)
2018-08-11 14:52:33.876 Error: Telegram:
Does anyone know how to solve this issue?
webrazor
Post by webrazor » Monday 13 August 2018 9:48
hmm after the update domoticz is not working anymore, problem with the database any solution for this?
2018-08-13 09:39:44.632 Status: Domoticz V4.9700 (c)2012-2018 GizMoCuz
2018-08-13 09:39:44.632 Status: Build Hash: a3a45906, Date: 2018-06-23 16:24:51
2018-08-13 09:39:44.634 Status: Startup Path: /home/webrazor/domoticz/
2018-08-13 09:39:44.654 Error: Database incompatible with this Domoticz version. (You cannot downgrade to an old Domoticz version!)
vwtune
Post by vwtune » Thursday 23 August 2018 16:16
When updating from V3.88.33 to V4.9700 on my RPI3 (in domoticz self) i got the following problems;
after updating, the most of my switches, timers and notifications are gone
Then after rebooting the RPI and login, Domoticz is back on the V3.88.33 version??? What i am doing wrong???
r33d
Post by r33d » Sunday 26 August 2018 0:36
I have problem after updating 3.9 to 4.9 in openwrt 18. After restore database, all my switches seems working, but pushbullet didn`t work anymore.I change api key but didn`t help. Problem is too with update Weather Underground API, didn`t update too. Email notification didn`t working too? In logs i see only info like this.
2018-08-25 23:14:37.366 (Wirtualny) Light/Switch (Gotowy)
2018-08-25 23:14:42.448 (Wirtualny) Light/Switch (Włączenie Domowe)
2018-08-25 23:14:42.455 Notification sent (pushbullet) => Failed
2018-08-25 23:14:43.475 (Wirtualny) Light/Switch (Gotowy)
2018-08-26 00:00:00.662 Sunrise: 05:37:00 SunSet: 19:38:00
2018-08-26 00:00:00.662 Day length: 14:01:00 Sun at south: 12:05:00
2018-08-26 00:00:00.663 Civil twilight start: 05:01:00 Civil twilight end: 20:14:00
2018-08-26 00:00:00.663 Nautical twilight start: 04:16:00 Nautical twilight end: 20:60:00
2018-08-26 00:00:00.663 Astronomical twilight start: 03:24:00 Astronomical twilight end: 21:52:00
2018-08-26 00:01:59.720 (Wirtualny) Light/Switch (Sabotaż)
2018-08-26 00:01:59.754 Notification sent (pushbullet) => Failed
2018-08-26 00:02:27.909 (Wirtualny) Light/Switch (Sabotaż)
2018-08-26 00:02:27.974 Notification sent (pushbullet) => Failed
2018-08-26 00:02:28.943 (Wirtualny) Light/Switch (Sabotaż)
2018-08-26 00:02:28.957 Notification sent (pushbullet) => Failed
2018-08-26 00:02:51.497 (Wirtualny) Light/Switch (Sabotaż)
2018-08-26 00:02:51.504 Notification sent (pushbullet) => Failed
WTF?
I try reinstall 3 times, clean install ( only add api and test ), install Python 3.6.5. Didn`t help :/ Pushover notification didn`t work too.I don`t understand.
nizaga
Post by nizaga » Tuesday 28 August 2018 16:17
hello,
I updated without any problem from jessie to stretch following:
https://linuxconfig.org/raspbian-gnu-li ... -stretch-9
I have a question about the release notes.
What is it exactly : " Implemented: ZWave node ID to log"¿? what and where to log?
r33d
Post by r33d » Wednesday 29 August 2018 16:43
Problem solved.
Install opkg install ca-bundle and opkg install ca-certificates. Pushbullet works, email unfortunately no.
meyland
Domoticz version: V3.8153
Post by meyland » Saturday 01 September 2018 10:51
Are there any plans for the next stable release of Domoticz where Philips Hue and Onkyo plugins are working?
regards
Peter
Antikillerbm
Post by Antikillerbm » Saturday 01 September 2018 20:55
I have tried to update release version, but every time had offline screen.
Only beta versions are working
What Im doing wrong?
Running on stable Debian GNU/Linux 9 (stretch)
vwstepha
Domoticz version: 4.97
Post by vwstepha » Sunday 02 September 2018 15:01
With this stable version, i can not reinstall the broadlink python in order to command my Sp2 plug with my pi!
It si normal? :?
i have see the github but no response.... :|
tks you very munch :mrgreen:
my log
2018-09-02 15:02:07.690 Status: User: maitre initiated a switch command (235/M/A Prise Lilou/Off)
2018-09-02 15:02:07.917 Status: Executing script: /home/pi/domoticz/scripts/smartplug1_stop.py
2018-09-02 15:02:09.564 Error: Error executing script command (/home/pi/domoticz/scripts/smartplug1_stop.py). returned: 256
Rpi Master 4.97 stable (Broadlink HS since 4.97.....)
Rpi slave 4.97 with 2 rflink(rts + 433)
basmeyer
Domoticz version: 3.5837
Post by basmeyer » Monday 03 September 2018 23:15
wonder24 wrote:
Monday 09 July 2018 22:16
On the web page I can see different installations but not a link to download it for Asustor. Can you provide a download link for a the latest stable version to be used with Asustor intel chips.
I have tried updating it from within the application, but it fails replying there is no update available.
What is needed to use the final and the beta versions on Asustor. I have tried contacting Asustor support but it seems they are waiting on your feedback.
Would like to start using the nice extra's implemented into the this version
I am going to bump this one up again.
The release that is avaible through the App Central of the Asustor NAS (AS6202T here) shows version 3.5837 which was released 03-11-2016.
In the meantime there is 4.9700.
Is the support for Asustor dead?
If not, a more or less rough estimation when to expect an update?
Any advice to better leave the Asustor NAS platform and focus on something else like a RaspberryPI welcome.
The version 3.5837 is getting a bit old now and we look forward to the new functionalities.
niclasc
Domoticz version: 4.9700
Post by niclasc » Thursday 06 September 2018 17:16
Any idea when the next stable will be released?
lost
Post by lost » Friday 07 September 2018 13:31
It was planned every month after this 4.9700, but everyone needs vacations I presume!
No problem waiting till ready & indeed a good idea to upgrade more often (maybe every month is quite short, every quarter would IMO be enough) to minimize the deltas between stables with big deltas that can create migration problems (like DB since old-stable, depending on users config, reason why I did not upgrade for now).
bjacobse
Post by bjacobse » Saturday 08 September 2018 11:43
Deleted this posting as it wasn't related to Domoticz, but something went wrong in my Jessie to Stretch upgrade
EmmanuelFR
Post by EmmanuelFR » Sunday 09 September 2018 16:54
It si normal? :?
It seems to be a known problem and I read that some people solved it using the beta version. As far as I'm concerned, I will simply wait for the next stable release and make a clean install (with a backup...).
