Domoticz does not see my Philips Hue Bulbs
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
sander71977
Target OS: Raspberry Pi
Re: Domoticz does not see my Philips Hue Bulbs
Post by sander71977 » Wednesday 04 July 2018 23:54
Version: v4.9700 (Stable)
Platform: Raspberry Pi 3B
Plugin/Hardware: Philips Hue
Description:
Lights are missing on all the Domoticz tabs.
They are in de Devices under Setup and can be turned on/off from there (so the link to the bridge still works)
Removed them from the used devices and re-added them: still not working
Disabled the Hue hardware and re-enabled: still not working
Deleted the Hue hardware and all devices. Re-connected everything: still not working!
Updated this evening because domoticz was suggesting it, but already regret I actually did.
Post by waaren » Thursday 05 July 2018 0:03
Description:
A lot of the problems users experience after a domoticz update are gone when the browsercache and appcache are cleared. There are also quite a number of posts on this forum related to these kind of problems.
to summarize and sorted from little effort to a bit more effort take these steps and check after each step if it address the issues you encounter.
- clear browser cache and app cache
- in www/js look for domoticz.js.gz, if its there remove it, (KEEP domoticz.js !! )
- use chrome incognito mode using [control] [shift] n
- restart domoticz
- rename the location of the original installation and install the new version to an empty target directory. Next copy database and scripts from the old location and fire it up.
Hope this will also solve your problem.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
lumjajo
Post by lumjajo » Friday 06 July 2018 20:21
I have the same issue with stable 9700 on stretch.
Hue Lights are visible but do not show their status unless switched by domoticz.
So if I switch the lights with the Hue app, I cannot see the status in domoticz.
Is this fixed in beta 9747?
Post by waaren » Friday 06 July 2018 23:50
Yes this is fixed now
EdddieN
Domoticz version: 4.9700
Post by EdddieN » Monday 09 July 2018 22:47
If it helps, I have ./updatebeta then the light appeared and then went back to ./updaterelease
all working now
11101101 - www.machinon.com
mikerijntje
Post by mikerijntje » Friday 20 July 2018 1:25
Can you tell me when this version included this fix will be released?
Post by waaren » Friday 20 July 2018 1:52
The fix is in all versions after V4.9727 So if you want that fix now, you need to move to Beta (which for me is quite stable too) I don't know when a next stable version will be released. That will be decided by @gizmocuz .
Please make sure you have a backup with a tested and working restore procedure before you update to a newer version.
hmjgriffon
Post by hmjgriffon » Wednesday 25 July 2018 19:35
I'm on 9700 and just set up hue yesterday same issue, anyone know when the fix will make it to prod? I'm not keen on running beta software on my home automation/home security system.
alaksandus
Post by alaksandus » Friday 03 August 2018 10:49
Still no update. Why is this taking so long? A lot of people use Philips Hue with Domotiz, fix is available so why not push it?
Not everybody want to use beta. Is it possible to gat a ETA on a new update?
rogerthn
Post by rogerthn » Monday 06 August 2018 20:37
Trying to say something more than +1 to see if my reply is left.
i.e. I do not like to run beta and I do wonder if it is possible to get an ETA?
EdwinK
Post by EdwinK » Monday 03 September 2018 19:55
gizmocuz wrote:
Sunday 24 June 2018 8:56
Can you enable accept new hardware in the settings, then disable the hue hardware, and enable it again
Now look in the devices view, you might have new devices
Seems to have fixed my problems with Hue.
Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | RFxcom | Dashticz V2
rogerthn
Post by rogerthn » Friday 07 September 2018 18:44
No :(
martijncas
Post by martijncas » Sunday 28 October 2018 19:41
I also cant detect new hue devices. Also tried the disable/enable (while accepting new hw) method...
Users browsing this forum: No registered users and 3 guests
