Help needed with script
drwurn
Target OS: Raspberry Pi
Post by drwurn » Monday 18 June 2018 19:58
What I want to accomplish is:
The light goes on at sunset, light goes out at 00:00
And the light goes on at 06:00 until sunrise. So these days the light stays out because sunrise is at 05:xx
Can't make it work.
niki_lauda
Re: Help needed with script
Post by niki_lauda » Monday 18 June 2018 20:40
Create a dummy switch Zonsopgang/or sunrise that switches a few minutes before sunrise or after if you like.
This is my script
snellejellep
Domoticz version: 4.1xxxx
Post by snellejellep » Monday 18 June 2018 21:00
i use the timer section for this:
raspberry pi | xiaomi gateway/vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
drwurn
Post by drwurn » Thursday 21 June 2018 7:50
It doesn't work with the timer section. The light goes on at 06.00 while sunrise has been.
snellejellep
Post by snellejellep » Thursday 21 June 2018 8:08
that is an isssue a am having too, when i notice that sunrise is before 6:00 i turn off the timers that turn the lights on in the morning, you can see that in the screenshot i send.
so if someone does have a script that can do this, or maby, i can figure something out with dzvents.
mrf68
Domoticz version: 3.4834
Post by mrf68 » Thursday 21 June 2018 8:44
To me, the blockly in the first post looks valid. “Can’t make it work” is too little info. Which part isn’t working? What does the log say at those specific moments that something should happen? For example: the log should say that the script has run at 00:00. Between 00:00 and 00:15 it should mention that 11 is turned off.
snellejellep
Post by snellejellep » Thursday 21 June 2018 13:06
i just created this dzvents script, i am gonna test that one tonight since it is dependant on the sunrise and sunset :)
		timer = { "at 1:00",
	              "at sunset",
	              "at sunrise",
	              "at 6:00"
	execute = function(dz, device)
		local garden_lights     = dz.groups("Tuinverlichting")  --group used to switch multiple garden lights/switches
		local morningtime       = 360                           --time in minutes after midnight sunrise should be for the garden lights to turn on
		if dz.time.matchesRule("at sunset")  then
		    garden_lights.switchOn()
		elseif dz.time.matchesRule("at 1:00") then
		    garden_lights.switchOff()
		elseif (sunriseinMinutes > "morningtime")  and dz.time.matchesRule("at 6:00") then
		elseif dz.time.matchesRule("at sunrise") then
drwurn
Post by drwurn » Thursday 21 June 2018 21:24
Let me know :)
snellejellep
Post by snellejellep » Thursday 21 June 2018 22:06
Let me know :)
update: it dit turn on the lights, now lets see if they are off tomorrow morning :)
drwurn
Post by drwurn » Friday 22 June 2018 9:47
And and?
snellejellep
Post by snellejellep » Friday 22 June 2018 9:55
it did work! it turned the garden lights off at 1:00
i only could not test the morning because obviously the sun rises way too early now :)
