problem in the logfile
gerardsoraya
Domoticz version: v3.8763
Post by gerardsoraya » Saturday 16 June 2018 12:44
hello,
i have an error in the logfile and i cant explain where its from, i googled it a lot but no answers found yet.
every 5 minutes the next problem is in the logfile:
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('313', '0')") : database disk image is malformed
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('314', '0')") : database disk image is malformed
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('3268', '50')") : database disk image is malformed
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('3269', '0')") : database disk image is malformed
2018-06-16 12:40:00.454 Error: SQL Query("INSERT INTO Percentage (DeviceRowID, Percentage) VALUES ('3273', '0')") : database disk image is malformed
2018-06-16 12:40:00.500 Error: SQL Query("DELETE FROM Percentage WHERE strftime('%s',datetime('now','localtime')) - strftime('%s',Date) > (SELECT p.nValue * 86400 From Preferences AS p WHERE p.Key='5MinuteHistoryDays')") : database disk image is malformed
ubuntu
rflink 433 mhz
rflink 868 mhz
p1 smart meter cable
toon thermostaat
otgw
pretty noob but whit google i've done a lot
Target OS: Raspberry Pi
Re: problem in the logfile
Post by waaren » Saturday 16 June 2018 13:01
The solution described here viewtopic.php?f=28&t=10984 might work for you
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
davidgomes
Post by davidgomes » Tuesday 31 July 2018 8:32
i had a issue with logfile that
I can see the log in Domoticz when i click on the log button.
Only is there a logfile, where i can see what happend, when my pc is off?
There is something wrong, so i hope i can see on this file,
And then i do not have to watch @ night to my p
Nox Showbox Mobdro
Post by waaren » Tuesday 31 July 2018 9:59
According the wiki for installing on Windows
"A page for setting up the Domoticz Log File Location Path is shown. The default path (C:\Program Files (x86)\Domoticz\log) is shown and can be edited. If you do not wish to retain the log file permanently, select a temp folder (c:\windowstemp for instance)."
So if you did not edit this path during installation the domoticz log should be there.
On linux you can choose in the startup script in /etc/init.d/ if you want the logging to an OS file or only the last couple of lines in memory. You can also choose how much is logged using logsettings. Don't know if this is the same on Windows.
