[Solved] Read loglines with json command skip Status logs Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Target OS: Raspberry Pi
Post by waaren » Thursday 14 June 2018 22:32
Version: V3.9639 (compiled locally)
Debian Stretch on RPI-3
I do not get any loglines starting with Status: when using domoticz_IP:domoticz_Port/json.htm?type=command&param=getlog
I do see the lines in the logfile on OS level and in the logwindow in the GUI.
Tried a couple of previous versions (until V3.9580) because I did see a recent update on logger.cpp but no result.
Should I now use an extra setting or parm to get these loglines ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
jvdz
Domoticz version: Stable
Re: Read loglines with json command skip Status logs
Post by jvdz » Thursday 14 June 2018 23:01
Looks like it defaults to level=1 log messages when the loglevel isn't provided.
Adding the loglevel allows for other messages to be retrieved like 2 for status messages:
http://192.168.0.??:8080/json.htm?type=command&param=getlog&loglevel=2
Jos
Post by waaren » Thursday 14 June 2018 23:11
@jvdz,
Many thanks Jos, I could not find it !
jvdz
Post by jvdz » Thursday 14 June 2018 23:16
I had to look in the source code to figure that our. ;)
Jos
Post by waaren » Thursday 14 June 2018 23:25
Jos
That is where I initially found the getlog json from but my development system was busy doing other stuff...
I will update the JSON wiki with this information. Can you please check what the return is on your prod system if you add the &loglevel
(I do not have versions before V3.8153
Thanks !
jvdz
Re: [Solved] Read loglines with json command skip Status logs
Post by jvdz » Friday 15 June 2018 9:27
As mentioned in the other thread: There was no change in the result returned when I added it to the url on V3.8153 so we should be able to safely add it to the function and it should work for both. :)
Jos
jvdz
Post by jvdz » Friday 15 June 2018 9:45
Just had a though to also check what the domoticz webpage does for log retrieval and that sends this url to retrieve all statussus in one go:
/json.htm?type=command&param=getlog&lastlogtime=0&loglevel=268435455
Jos
Post by waaren » Friday 15 June 2018 11:16
@jvdz. thanks !
I will update the wiki and also post a question in slack or GITHub on how we can get this kind of information documented without digging in the sources or using network monitors :)
Users browsing this forum: GSV3Miac and 4 guests
