Kaku Action shop switch settings
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
freijn
Target OS: Raspberry Pi
Post by freijn » Thursday 14 June 2018 21:47
Guys,
For a while I am using the cheap Atcion shop kaku switches. Happy with it till now....
The older version had dip switches I could set for the address.
The newer are self learning. With my first set it was working fine. Now i got an aditional set and got troubles. :-(
Apparently i have in my system the 4th button ( all on / all off ) defined. As when a light A has to go off and on. Light A works.
Now I have a light B and I can make it go on and off again. No issues so far only,
When I switch off light A , light B follow the light A as well.
Attached an example switch setting I have use. Anybody knows the magic of these switch settings? Is 1 array for ALL ON/OFF ?
Many thanks for your time
Frank
FrankVZ
Re: Kaku Action shop switch settings
Post by FrankVZ » Thursday 14 June 2018 22:41
I use those too (kaku) and no problems so far with switching on/off.
I use the older types (with code wheels/ACR) the less old (without code wheelsACR+AC) and the newest (only AC, no ACR allowed) all together.
With the use of domoticz I use a script so I can control all of them with the same remote. No problems so far.
I remember that I had some undefined troubles with Kaku and the RFX too. I dont remember if it was the final solution, but I changed the code on the RFX with a number, not containing the "00". But that is easy for you to give it a try?
But you may have programmed the different remotes in the switches, and some commands by the DZ/RFX too?
They might interfere with eachother or get some unexpected results.
Best is in that case: be sure that mutiple switching is done by the DZ.
hth, Frank
freijn
Post by freijn » Friday 15 June 2018 8:26
Hi Frank
Will do some aditional testing in the weekend ( if it rains :-) )
Will share the result here....
Thanks !
Users browsing this forum: No registered users and 9 guests
