cannot autostart Domoticz
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
marcing1
Post by marcing1 » Wednesday 13 June 2018 22:04
I have orange pi pc with ARMBIAN 5.38 stable Debian GNU/Linux 9 (stretch) 4.14.18
when I test : ./domoticz , it works
when I start: service domoticz.sh start
then:
root@orangepipc:~# service domoticz.sh status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
Active: active (exited) since Wed 2018-06-13 19:54:45 UTC; 2s ago
Docs: man:systemd-sysv-generator(8)
Process: 2652 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUC
Process: 2685 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/S
Jun 13 19:54:45 orangepipc systemd[1]: Starting LSB: Home Automation System...
Jun 13 19:54:45 orangepipc systemd[1]: Started LSB: Home Automation System.
I tested lot of suggestion but it not works. example: viewtopic.php?f=4&t=17447
marcing1
Re: cannot autostart Domoticz
Post by marcing1 » Thursday 14 June 2018 23:06
I found solution my problem.
Re: Instalation problem Domoticz
Post by Jan Jansen » Friday 29 September 2017 13:52
Try a fresh install and reload database.
- burn stretch
- set raspi-config
- wget http://mirrordirector.raspbian.org/rasp ... _armhf.deb
- sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
- sudo apt-get install libpython3.4
- sudo apt-get update and upgrade
- sudo reboot
- sudo curl -L install.domoticz.com | sudo bash
- reload database
Users browsing this forum: vchecco and 2 guests
