V3.9631 - Nest Plugin OAuth errors
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
poudenes
Domoticz version: 3.8993
Post by poudenes » Wednesday 13 June 2018 14:48
After less then 12 hours i got this in error log:
Hardware: Nest
Plugin: NestThermostat/Protect OAuth
The Nest Thermostat / Protect with username and password is working correct. Only the smoke detectors are not septette by Smoke or CO
Thats why i want the OAuth way. Then you get Smoke and CO devices separate
2018-06-13 13:41:38.059 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 13:41:38.060 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 13:42:12.145 Error: NestOAuthAPI: Error getting devices!
2018-06-13 13:50:35.000 Error: NestOAuthAPI: Error getting devices!
2018-06-13 14:30:37.548 Error: NestOAuthAPI: Error getting devices!
2018-06-13 14:31:08.907 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:31:08.908 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:31:30.680 Error: Nest OAuth hardware (2) nothing received for more than 1 Minute!....
2018-06-13 14:31:31.684 Error: Restarting: Nest OAuth
2018-06-13 14:31:38.335 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:31:38.336 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:32:09.700 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:32:09.700 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:32:41.127 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:32:41.128 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:33:00.928 Error: Nest OAuth hardware (2) nothing received for more than 1 Minute!....
2018-06-13 14:33:01.930 Error: Restarting: Nest OAuth
2018-06-13 14:33:08.485 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:33:08.485 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:33:39.914 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:33:39.914 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:34:11.279 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:34:11.280 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:34:30.150 Error: Nest OAuth hardware (2) nothing received for more than 1 Minute!....
2018-06-13 14:34:31.154 Error: Restarting: Nest OAuth
2018-06-13 14:34:37.599 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:34:37.600 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:35:08.980 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:35:08.981 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:35:40.359 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:35:40.359 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:36:00.541 Error: Nest OAuth hardware (2) nothing received for more than 1 Minute!....
2018-06-13 14:36:01.541 Error: Restarting: Nest OAuth
2018-06-13 14:36:08.783 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:36:08.783 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:36:40.100 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:36:40.101 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:37:11.583 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:37:11.583 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:37:30.384 Error: Nest OAuth hardware (2) nothing received for more than 1 Minute!....
2018-06-13 14:37:31.386 Error: Restarting: Nest OAuth
2018-06-13 14:37:37.888 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:37:37.888 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:38:09.328 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:38:09.328 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:38:40.715 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:38:40.715 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:39:00.607 Error: Nest OAuth hardware (2) nothing received for more than 1 Minute!....
2018-06-13 14:39:01.608 Error: Restarting: Nest OAuth
2018-06-13 14:39:08.080 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:39:08.080 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:39:39.511 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:39:39.511 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:40:10.952 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:40:10.952 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:40:30.853 Error: Nest OAuth hardware (2) nothing received for more than 1 Minute!....
2018-06-13 14:40:31.853 Error: Restarting: Nest OAuth
2018-06-13 14:40:38.390 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:40:38.390 Error: NestOAuthAPI: Login failed: token did not validate.
2018-06-13 14:41:11.238 Error: NestOAuthAPI: Error getting structures!
2018-06-13 14:41:44.113 Error: NestOAuthAPI: Error getting structures!
2018-06-13 14:42:00.971 Error: Nest OAuth hardware (2) nothing received for more than 1 Minute!....
2018-06-13 14:42:01.972 Error: Restarting: Nest OAuth
2018-06-13 14:42:08.489 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: HTTP/1.1 307 Temporary Redirect
2018-06-13 14:42:08.490 Error: NestOAuthAPI: Login failed: token did not validate.
RPi3 with OSMC - RPi3 with Domoticz - Dashticz - MiLight - Nanolead Aurora - KaKu - Logitech Hamony - Nest - RFLink
williamjonas
Target OS: OS X
Re: V3.9631 - Nest Plugin OAuth errors
Post by williamjonas » Saturday 07 July 2018 12:47
hello,
Ok, so update to this issue. Successfully uninstalled the the NST Manager and NST Automations using instructions that sent to another user. I reinstalled per the instructions, OAuth is enabled, and all smart apps and device handlers are reinstalled. I've published for me and saved. I only installed the Nest Thermostat (I have 3), Weather, and Presence. I've checked my Nest account and see no Works with Nest connections. ST is not listed. Is there something I am missing with the Works with Nest? I still get the "Oops! We encountered an error. Please try again" error message. Is there something that you @tonesto7 need to reset to allow me to authorize the Works with Nest connection?
Users browsing this forum: No registered users and 4 guests
