ESP8266 MQTT switch with local on/off and feedback
Everything about esp8266 and more.
SweetPants
Domoticz version: V4.9701
Post by SweetPants » Monday 11 June 2018 19:53
Project Scope:
When entering my house I want to be able to switch the light in the halway automatically between sunset and sunrise. So when the door opens, switch On the light for say 1-2 minutes and switch Off again using dzVentz. But I also want to be able to switch on/off the light using the existing wall switch(es).
This could be done using an extra (ESP8266 driven) relay in parallel with the original wall switch, but then you are not able to switch off the lights anymore with the wall switch and this is not suitable when having a hotel circuit (2 or more switches in series)
This could be solved by buying (expensive) wall switches which most of the time do not fit into the wall box or are totally different from the original.
Solution:
I've created an ESP8266 enabled switch that can be switched using MQTT, but also takes the switch wire from the wall switch as an input and do local switching if needed. When the wall switch is toggled, the switch also sends an MQTT update to domoticz to update the current switch state. The module is located in or near the lamp, so in case of a hotel circuit, it also works.
First test looks promising
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
kimot
Target OS: Raspberry Pi
Domoticz version: v3.8153
Re: ESP8266 MQTT switch with local on/off and feedback
Post by kimot » Tuesday 12 June 2018 23:05
ESPeasy works the same way without need scripts in Domoticz and works if Domoticz is down too.
Domoticz only sends "events" sunset, sunrise, switch slamp ( for remote control ) etc. Other ESPeasy sends door contact state to first (lamp) ESPeasy
This ESPeasy monitors mechanical switch state too, reports lamp state back to Domoticz and control lamp relay ( with timers if needed )
SweetPants
Post by SweetPants » Wednesday 13 June 2018 14:50
My solution does that too, no need for scripts, and no need to modify wall switches, just sense the presence of a switch signal, but you need some additional hardware to do that. And how about hotel circuits with two or more wall switches?
Edit: Have a second one running now on a 3 switch hotel circuit. Still looking good
