Simple 'on' command Topic is solved
drwurn
Target OS: Raspberry Pi
Simple 'on' command
Post by drwurn » Sunday 10 June 2018 17:19
I'm new here and new to domoticz. I'm trying to switch a dummy switch with
http://<IP ADRESS>:8080/json.htm?type=command&param=switchlight&idx=1&switchcmd=on
but results in
"message" : "Error sending switch command, check device/hardware !",
"status" : "ERROR",
"title" : "SwitchLight"
obviously I'm missing something (or more).
The IDX is correct and the switch is not protected.
I've red something about the localnetwork but not sure what IP to put there.
tested it with 127.0.0.1 as localnework and
http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=1&switchcmd=on
in the 'on action' of the virtual switch.
What am I missing?
jvdz
Domoticz version: Stable
Re: Simple 'on' command
Post by jvdz » Sunday 10 June 2018 17:29
Are you sure about IDX 1?
You can check the appropriate IDX in the devices tab of open this url to show them all via JSON:
http://<IP>:8080/json.htm?type=devices
-or- check a specific device via json with url :
http://<IP>:8080/json.htm?type=devices&rid=<IDX>
( replace <IP> and <IDX> with appropriate values)
Jos
EDIT: Fixed typo
drwurn
Post by drwurn » Sunday 10 June 2018 17:35
Yes positive about IDX1.
First device I've added after a fresh reinstall.
confirmes IDX1
http://<IP>:8080/json.htm?type=devices,&rid=<IDX>
gives status ERR
Post by waaren » Sunday 10 June 2018 18:22
gives status ERR
remove the comma after devices.
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave , dzVents 2.4.n, Amazon echo
jvdz
Post by jvdz » Sunday 10 June 2018 18:23
What details are shown in the devices tab for this IDX 1 dummy switch?
... and ofcourse what @waaren said! :)
Jos
drwurn
Post by drwurn » Sunday 10 June 2018 18:31
http://<IP>:8080/json.htm?type=devices&rid=1
gives
"ActTime" : 1528648010,
"ServerTime" : "2018-06-10 18:26:50",
"Sunrise" : "05:09",
"Sunset" : "21:57",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 2,
"HardwareName" : "Dummy (hardware)",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveDimmer" : false,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "67",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2018-06-10 16:40:49",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 0,
"Name" : "TelefoonWerner",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "aHR0cDovLzEyNy4wLjAuMTo4MDgwL2pzb24uaHRtP3R5cGU9Y29tbWFuZCZwYXJhbT1zd2l0Y2hsaWdodCZpZHg9MSZzd2l0Y2hjbWQ9b24=",
"StrParam2" : "",
"SubType" : "X10",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Lighting 1",
"TypeImg" : "lightbulb",
"Unit" : 5,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "1"
"status" : "OK",
"title" : "Devices"
drwurn
Post by drwurn » Sunday 10 June 2018 18:32
Jos
1 Dummy (hardware) C 5 TelefoonWerner Lighting 1 X10 Off
jvdz
Post by jvdz » Sunday 10 June 2018 19:00
Think I know the issue: The last bit needs to be with a capital O in On: &switchcmd=On
so:
http://<IP ADRESS>:8080/json.htm?type=command&param=switchlight&idx=1&switchcmd=On
Jos
drwurn
Post by drwurn » Sunday 10 June 2018 19:28
GENIUS!!
Thanks a lot, you've just maked my day :)
