Zwave Aetonic S2 stick Topic is solved
BartSr
Target OS: Raspberry Pi
Post by BartSr » Sunday 10 June 2018 13:36
Dear all. I used the zwave stick with domoticz running on pc. I included a swich with kw meter facility. This worked well in domoticz.
Than i placed same stick in raspberry pi with domoticz. Stick can be seen in hardware but list with nodes is empty. Also not possible to include more devices (switches).
Do I overlook something?
Kr
-Bart
D'rMorris
Re: Zwave Aetonic S2 stick
Post by D'rMorris » Monday 11 June 2018 10:47
I don't have a Z-wave stick, but I think that I read somewhere that you need to exclude the device first on the "old" machine before you can include it in the "new" machine?
gizmocuz
Post by gizmocuz » Monday 11 June 2018 15:57
You adjusted the com port setup ?
You do not have to exclude/include again
BartSr
Post by BartSr » Monday 25 June 2018 10:36
adjusting the com port setup did the trick
thanks!
antwan
Domoticz version: Latest
Post by antwan » Monday 25 June 2018 17:21
Check the wiki for persistent USB.
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433E, RFXtrx868, P1 Converter, TE923 display, Voltcraft CO-20, SolarEdge proxy
Cubietruck 2: Aeotec Z-Wave, RFXtrx433E
