No log on latest betas Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
mrkrabs
Target OS: Raspberry Pi
Domoticz version: 3.9589
Post by mrkrabs » Saturday 09 June 2018 8:09
Version: 9599 (happened on previous release as well)
Platform: latest raspbian strech
Plugin/Hardware: All plugins are disabled/rasperry pi zero w
Currently domoticz do not log anything when started with loglevel=0. nothing was changed from my side apart from updating to latest beta, so it must be something in that release as 2 days ago logging was working fine. is someone experiencing the same behavior?
SweetPants
Domoticz version: V4.10196
Re: No log on latest betas
Post by SweetPants » Saturday 09 June 2018 8:41
I'm not sure if you can select 0 anymore.
domoticz --help shows:
-loglevel (combination of: normal,status,error,debug)
Ubuntu 16.04.5 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
Xztraz
Post by Xztraz » Saturday 09 June 2018 15:19
had same problem. only start and stop logging with loglevel 0
"loglevel normal" works fine
Corrected the wiki to say normal
gerardosamara
Domoticz version: 4.9701
Post by gerardosamara » Monday 11 June 2018 19:39
Hi ,
I had the same issue on the beta 9625 .
The domoticz manual also has to be updated page 8 :
Command Line parameters
The following command line parameters are available:
loglevel (0 =All, 1 =Stat us+Erro r, 2 =Erro r)
Thank you
Domoticz Remote server RPi3B+ & WD PI Drive Beta V4.9701 , Domoticz Slave Beta RPI3B V4.9701 + App Android Domoticz Lite V0.1.452 & Imperihome Pro V40107
Zwave+ Z Stick Z90 USB dongle + USB300 Ocean GW dongle
jake
Post by jake » Wednesday 13 June 2018 22:15
I change the domoticz.sh file from "loglevel 0" to "loglevel normal". This makes the log 'tick' again. However, I used to see the updates of all devices, but in the 'Status' tab in a green font all the 'status' of script output. This used to be nice to have a better focus on the 'status' log lines.
Only when I make it into "loglevel status", I see plenty of status messages, but zero device updates.
Is this behaviour for both settings normal? Does it differ from the "loglevel 0"?
jake
Post by jake » Monday 18 June 2018 7:37
jake wrote:I change the domoticz.sh file from "loglevel 0" to "loglevel normal". This makes the log 'tick' again. However, I used to see the updates of all devices, but in the 'Status' tab in a green font all the 'status' of script output. This used to be nice to have a better focus on the 'status' log lines.
Should I use multiple statements, like 'loglevel normal, status, error' or something like that? I already tried the previous sentence, but that gives the same result as 'loglevel normal', only the normal logging.
Sergio
Domoticz version: 3.9639
Post by Sergio » Monday 18 June 2018 21:53
With no logs, are you referring to the log to disk or the Log page in the web gui?
I have a completely empty Log page since the "hiding error tab" change was introduced. Of course I've cleared cache and appcache several times.
SweetPants
Post by SweetPants » Monday 18 June 2018 22:30
Do you see messages in domoticz.log?
Sergio
Post by Sergio » Monday 18 June 2018 22:43
No. But I'm using tmpfs. I'll investigate if the symlink is missing.
Enviado desde mi MI 5s Plus mediante Tapatalk
jake
Post by jake » Monday 18 June 2018 23:45
With loglevel normal I see the same log lines in the GUI as in domoticz.log.
However, print commands of lua scripts etc are not visible anymore. Normally a weather script throws in a few error lines a day, because it is running for more than 10 seconds. I now see none of that.
SweetPants
Post by SweetPants » Tuesday 19 June 2018 8:31
Try setting -loglevel normal,status,error
jake
Post by jake » Tuesday 19 June 2018 9:09
Thanks, that's it! I tried already "-loglevel normal, status, error" and I am pretty sure that this didn't work. Now I skipped the spaces in between normal, status and error, it does work. I finally have the status messages back.
sineverba
Post by sineverba » Tuesday 19 June 2018 17:43
[...]I have a completely empty Log page since the "hiding error tab" change was introduced. Of course I've cleared cache and appcache several times.
I'm also missing the error tab... where is the new option??? Thank you
Sergio
Post by Sergio » Tuesday 19 June 2018 18:04
It's supposedly hidden until you've got an error.
sineverba wrote: I'm also missing the error tab... where is the new option??? Thank you
sineverba
Post by sineverba » Tuesday 19 June 2018 19:38
@Sergio right, I can confirm.
Thank you
SweetPants
Post by SweetPants » Tuesday 19 June 2018 19:42
Did you ever read the posts before? viewtopic.php?f=6&t=23773#p183897 The solutions is in there
sineverba
Post by sineverba » Wednesday 20 June 2018 0:52
Yes Sweet Pants. And I thanked the answer.
Users browsing this forum: No registered users and 9 guests
