Can't debug python plugin
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
hboisselle
Target OS: Raspberry Pi
Post by hboisselle » Friday 08 June 2018 18:24
Hello there,
I've been trying to debug a python plugin without success for quite a while now, I was wondering if you could help me a bit. I'm not sure if this is a bug or just me not understanding how to properly debug.
First and foremost, I am running Domoticz 3.9483 on a Lubuntu 18.04 VM on OSX. I'm using python 3.6.5 . I'm just trying to set a breakpoint and attach to rpdb through telnet. When I add the hardware on Domoticz for the following plugin, the log never shows any of the messages I've put into the callbacks. Rpdb doesn't start either.
Do I have to compile Domoticz in debug to make this work? I've set the -debug flag in domoticz.sh.
Your help is appreciated!
# Basic Python Plugin Example
# Author: GizMoCuz
<plugin key="BasePlug" name="Basic Python Plugin Example" author="gizmocuz" version="1.0.0" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://www.google.com/">
    <description>
        <h2>Plugin Title</h2><br/>
        Overview...
        <h3>Features</h3>
        <ul style="list-style-type:square">
            <li>Feature one...</li>
            <li>Feature two...</li>
        </ul>
        <h3>Devices</h3>
            <li>Device Type - What it does...</li>
        </ul>
        <h3>Configuration</h3>
        Configuration options...
    </description>
    <params>
    </params>
</plugin>
import Domoticz
class BasePlugin:
    enabled = False
    def __init__(self):
        #self.var = 123
        return
    def onStart(self):
        Domoticz.Log("onStart called")
        Domoticz.Debugging(1)
        Domoticz.Log("Debugger started!")
        import rpdb
        rpdb.set_trace()
    def onStop(self):
        Domoticz.Log("onStop called")
        import rpdb
        rpdb.set_trace()
    def onConnect(self, Connection, Status, Description):
        Domoticz.Log("onConnect called")
        import rpdb
        rpdb.set_trace()
    def onMessage(self, Connection, Data):
        Domoticz.Log("onMessage called")
        import rpdb
        rpdb.set_trace()
    def onCommand(self, Unit, Command, Level, Hue):
        Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
        import rpdb
        rpdb.set_trace()
    def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
        Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
        import rpdb
        rpdb.set_trace()
    def onDisconnect(self, Connection):
        Domoticz.Log("onDisconnect called")
        import rpdb
        rpdb.set_trace()
    def onHeartbeat(self):
        Domoticz.Log("onHeartbeat called")
        import rpdb
        rpdb.set_trace()
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onConnect(Connection, Status, Description):
    global _plugin
    _plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
    global _plugin
    _plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
    global _plugin
    _plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
    global _plugin
    _plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
    global _plugin
    _plugin.onDisconnect(Connection)
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
    # Generic helper functions
def DumpConfigToLog():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
    Domoticz.Debug("Device count: " + str(len(Devices)))
    for x in Devices:
        Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
        Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
        Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
    return
divyadabgar
Target OS: OS X
Re: Can't debug python plugin
Post by divyadabgar » Thursday 28 June 2018 12:52
hello,
You can launch a Python program through pdb by using pdb myscript.py or python -m pdb myscript.py.
There are a few commands you can then issue, which are documented on the pdb page.
Some useful ones to remember are:
b: set a breakpoint
c: continue debugging until you hit a breakpoint
s: step through the code
n: to go to next line of code
l: list source code for the current file (default: 11 lines including the line being executed)
u: navigate up a stack frame
d: navigate down a stack frame
p: to print the value of an expression in the current context
If you don't want to use a command line debugger, some IDEs like Pydev have a GUI debugger.
Users browsing this forum: No registered users and 4 guests
