domoticz.sh does not run
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
glory50
Post by glory50 » Thursday 07 June 2018 22:44
Version: 3.8153
Platform: Linux Mint 18.3 Cinnamon 64 bit
Description:
I deleted domoticz.sh from /etc/init.d/. After that, I copied it again from /home/user/domoticz/ folder. Then I did:
sudo cp domoticz.sh /etc/init.d
sudo chmod +x /etc/init.d/domoticz.sh
sudo update-rc.d domoticz.sh defaults
But the script does not run.
ho@dom ~ $ sudo service domoticz.sh status
\u25cf domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; bad; vendor preset: enabled)
Active: active (exited) since Thu 2018-06-07 22:15:09 CEST; 1min 23s ago
Docs: man:systemd-sysv-generator(8)
Process: 1702 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
I can run domoticz binary manually from bash with or without arguments, it works. It worked fine before, but after deleting and new copy to /etc/init.d, no execution. How could I debug it? There are no messages in syslog about it.
Any clue what could be wrong?
dextm80
Domoticz version: 3.9527
Re: domoticz.sh does not run
Post by dextm80 » Friday 08 June 2018 10:13
try cd domoticz
./domoticz
and post results
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
2x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
Users browsing this forum: Hein73 and 7 guests
