Redirected to offline page when accessing Domoticz remotely
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
quack3d
Post by quack3d » Wednesday 06 June 2018 15:57
When I try to access Domoticz remotely (outside LAN) I get a login window. Then I log in like I use to but get redirected to DOMOTICZ OFFLINE even though it's online.
It used to work just fine.
Here is the console from browser:
jquery-3.3.1.min.js:2 GET https://ip:port/json.htm?type=command&param=getconfig 403 (Forbidden)
send @ jquery-3.3.1.min.js:2
ajax @ jquery-3.3.1.min.js:2
$rootScope.GetGlobalConfig @ app.js:984
successCallback @ LoginController.js:38
(anonymous) @ angular.min.js:137
$digest @ angular.min.js:148
$apply @ angular.min.js:151
l @ angular.min.js:103
t @ angular.min.js:108
A.onload @ angular.min.js:109
load (async)
(anonymous) @ angular.min.js:108
n @ angular.min.js:105
(anonymous) @ angular.min.js:102
(anonymous) @ app.js:187
dispatch @ jquery-3.3.1.min.js:2
y.handle @ jquery-3.3.1.min.js:2
custom.js:861 THEMEJS - URL change detected
custom.js:508 https://ip:port/#/Offline
custom.js:515 THEME JS - pageChangeDetected. currentPage was login
custom.js:518 THEME JS - pageChangeDetected. currentPage is offline
custom.js:536 +++ pagechangedetected: theme object on next line. Empty? false
custom.js:537 {type: "theme", name: "Aurora", description: "This is a dark theme for Domoticz", license: "GPL-2.0+", version: "1", …}
custom.js:573 THEME JS - user variable ID was NOT found inside theme object. Will try to get user variables list from Domoticz.
custom.js:611 THEME JS - NEW BACK END
jquery-3.3.1.min.js:2 GET https://ip:port/json.htm?type=command&param=getuservariables 401 (Unauthorized)
checkIfDomoticzHasThemeSettings @ custom.js:192
pageChangeDetected @ custom.js:574
(anonymous) @ custom.js:867
hashchange (async)
k.url @ angular.min.js:50
h @ angular.min.js:120
(anonymous) @ angular.min.js:124
load (async)
custom.js:238 The theme was unable to check if Domoticz had theme settings. Permission denied? Still on login page? No connection? Stopping..
custom.js:634 ____load observer fired
custom.js:635 (2) [MutationRecord, MutationRecord]
custom.js:640 loadobserver: currentPage = offline
custom.js:641 loadobserver: frontend = false
custom.js:651 __observer: A new mainview was loaded.
custom.js:726 THEME JS - now in backend improvements
custom.js:115 THEME JS - areweonmobile: checking if on mobile device
custom.js:1092 THEME JS - doing once per page things.
snellejellep
Target OS: Raspberry Pi
Domoticz version: 4.1xxxx
Re: Redirected to offline page when accessing Domoticz remotely
Post by snellejellep » Wednesday 06 June 2018 16:08
dit you try to remove cache and other browser stuff?
raspberry pi | xiaomi gateway/vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
quack3d
Post by quack3d » Wednesday 06 June 2018 16:11
Yeah. Even in inkognito and on a new browser I have the problem.
quack3d
Post by quack3d » Wednesday 13 June 2018 11:39
This is now fixed. Probably this one: https://github.com/domoticz/domoticz/issues/2469
Users browsing this forum: Baidu [Spider], InMySights, juuzo and 5 guests
