Automatically sunscreen down temperature
remko2000
Target OS: Raspberry Pi
Post by remko2000 » Monday 04 June 2018 20:26
I try to link my sunscreen (' scherm slaapkamer' ) to a sensor value (' temperatuur buiten' ). I want my sunscreen to go down above 22 degrees (if it is not already down) and only during the day within a certain time. I made this blocky:
Schermafbeelding 2018-06-04 om 20.22.59.png (24.76 KiB) Viewed 1857 times
This should work, however, he does not. What am I doing wrong now?
kuifje
Re: Automatically sunscreen down temperature
Post by kuifje » Tuesday 05 June 2018 8:15
Remko2000,
Would you try to set the time to OR instead of AND because it can never be 9 and 21.
Hope this will do the job.
Greetsz
Kuifje
CaesarPL
Post by CaesarPL » Tuesday 05 June 2018 9:10
Use dzVents. Really.
mrf68
Domoticz version: 3.4834
Post by mrf68 » Tuesday 05 June 2018 9:12
I think the time setting is correct. It says > 09:00 and < 21:00, so for example 10:34 is > 09:00 and < 21:00. If you change the AND to OR, it will always be true, because any time after 09:00 will be > 09:00 and any time before 09:00 will be < 21:00.
StanHD
Post by StanHD » Tuesday 05 June 2018 18:48
Just a thought:- When you look in the "current states", does the "scherm slaapkamer" report as on or off, or maybe "Open or Close"?
Domoticz Slave - Asrock Ion - Linux, Python:- Broadlink RM2, Sonos
remko2000
Post by remko2000 » Tuesday 05 June 2018 20:00
I changed the and to or but no improvement. The current states are on or off. This is no my blocky:
Schermafbeelding 2018-06-05 om 19.57.43.png (25.75 KiB) Viewed 1794 times
Eddiever
Domoticz version: V4.9700
Post by Eddiever » Tuesday 05 June 2018 20:29
I assume you are from the Netherlands (or Belgium) you can delete the time > 9:00. I don't think it will be 22 degrees between 0:00 and 09:00. Please do check the Show current states to see if it really is on/off and not open/closed.
RPi 2B with Domoticz and cam module RPi 3 with cam module
1 rftxtrx433E module 1 solar-edge SE-3500
1 Sonoff Touch 3 Sonoff wifi swithes 6 kaku modules
remko2000
Post by remko2000 » Tuesday 05 June 2018 21:03
In the log it is on/off but in the current state its open/close. So I changed it to open/close now in my blocky. In the log I see:
EventSystem: Event triggered: Script screen aan test_1 (and repeating)
but nothing happening.
snellejellep
Domoticz version: 4.1xxxx
Post by snellejellep » Wednesday 06 June 2018 9:25
@remko2000 the and blocks are stacked the wrong way around, if you stack in the second box of the and box and not in the first as you did here it will have a better chance of working. had this problem myself and that was the solution for me
raspberry pi | xiaomi gateway/vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
remko2000
Post by remko2000 » Thursday 07 June 2018 21:42
Ok I've changed the stacked blocks, it's now:
Schermafbeelding 2018-06-07 om 21.40.18.png (25.26 KiB) Viewed 1690 times
Is this better?
gerardsoraya
Domoticz version: v3.8763
Post by gerardsoraya » Sunday 10 June 2018 7:50
i have it already working like the picture below.
i only have the problem i now get every minute or every 10 minutes the notification. is there someone who knows the reason of that?
my theorie it is because the temperature is also changing?
ubuntu
rflink 433 mhz
rflink 868 mhz
p1 smart meter cable
toon thermostaat
otgw
pretty noob but whit google i've done a lot
Eddiever
Post by Eddiever » Sunday 10 June 2018 11:27
@gerardsoraya, make an extra check on the screens. In the If statement add the line with temperature with an AND statement in which you check if the screens are open. And in de Else if statement add the check if the screens are closed. This should prevent receiving extra messages.
remko2000
Post by remko2000 » Sunday 10 June 2018 20:11
I think that this in blocky doesnt work very well so I want something like this in LUA. I see some examples combined with weatherstation info. I want a basic script which send my screen down combined with my temperaturesensor (and looks if the screen is already down). Maybe with notification? Does anyone have something like this and want to post this script?
remko2000
Post by remko2000 » Wednesday 13 June 2018 19:55
This is now my blocky but it still doesn' t work. I've tried many variations but still no solution. Anyone?
Schermafbeelding 2018-06-13 om 19.53.25.png (36.99 KiB) Viewed 1545 times
Eddiever
Post by Eddiever » Wednesday 13 June 2018 20:33
I wish I could tell you what is wrong but I don't. What about if you try to keep it simple. Delete the time part. Just use the temperature and the status of the bedroom screen (scherm slaapkamer).
What if you try:
(replace test with scherm slaapkamer)
najtram
Domoticz version: v4.9700
Post by najtram » Thursday 21 June 2018 12:21
I had something strange in a similar situation. In the picture you can see my working solution.
Somehow open/close needs to be switched with on/off, but conditional states needs to use open/close. Maybe a bug?
Schermafbeelding 2018-06-21 om 10.54.54.png (127.64 KiB) Viewed 1374 times
Domoticz on Raspberry Pi 3 with USB RFLink Gateway at 433 Mhz for several KAKU switches. Bluetooth Soma Smart Shades. USB Opentherm Gateway connected to Remeha iSense with Remeha Tzerra boiler. ITHO ecofan RFT (ESP8266+CC1101). Almost running homebridge.
gerardsoraya
Post by gerardsoraya » Thursday 21 June 2018 12:55
Eddiever wrote:@gerardsoraya, make an extra check on the screens. In the If statement add the line with temperature with an AND statement in which you check if the screens are open. And in de Else if statement add the check if the screens are closed. This should prevent receiving extra messages.
I made the blockly as i onderstanded the way you have said, the notification keeps on sending every 10 minutes. Image
Verstuurd vanaf mijn SM-G965F met Tapatalk
ubuntu
rflink 433 mhz
rflink 868 mhz
toon thermostaat
otgw
remko2000
Post by remko2000 » Sunday 24 June 2018 10:01
It seems that this blocky finally works:
Schermafbeelding 2018-06-24 om 09.56.21.png (38.73 KiB) Viewed 1300 times
I would likt to add a notification (prowl) but I don't want a message every 10 minutes. How can I prevent this?
najtram
Post by najtram » Monday 25 June 2018 14:07
So with the answer of remko2000, this seems to be a real issue. Does someone know where to do a bugreport or look up if this is already known?
Eddiever
Post by Eddiever » Monday 25 June 2018 20:22
@Remko2000, just add the notification. And then see if you receive it every 10 minutes. @gerardsoraya, what does you log tell you?
