GoodWe stopped working Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Polyphemus
Target OS: Raspberry Pi
Post by Polyphemus » Monday 04 June 2018 19:12
The URLs in /hardware/GoodweAPI.cpp do not work anymore because of GDPR/AVG as stated on their website.
The correct URLs are:
https://eu.goodwe-power.com/Mobile/GetM ... ?userName=
https://eu.goodwe-power.com/Mobile/GetM ... stationId=
I was only able to check the first, by username, but I presume the other two will work too.
klaaspiet
Re: GoodWe stopped working
Post by klaaspiet » Tuesday 05 June 2018 15:33
i got the same problem here also.
how dit you solve this problem
greets klaas
louwerse
Domoticz version: 3.8153
Post by louwerse » Thursday 07 June 2018 17:02
I have the same problem. Every minute my log is displaying the following error: Error: GoodweAPI: Invalid user data received!
I'm running version 3.8153 on a Raspberry PI.
Is there any possibility to manually change the URL's where the GoodweAPI is communicating with?
louisL
Post by louisL » Friday 08 June 2018 22:08
The others seem to work as well (if you are in Europe). Strictly speaking the URL needs to be set depending on where you are located: eu.goodwe-power.com for Europe, au.goodwe-power.com for Oceania and otherwise hk.goodwe-power.com.
I am working on some patches to make the goodwe connections work again.
Louis
louisL
Post by louisL » Thursday 14 June 2018 21:31
Louis
The Domoticz code in GIT *(development brach) now contain the fixes for the change of the goodweAPI that implement the changes required for the server split. Please not that you need to set the region (Gloval, Oceania oe Europe) in the hardware settings
Polyphemus
Post by Polyphemus » Sunday 17 June 2018 21:22
Works! Thanks! :D
Users browsing this forum: No registered users and 7 guests
