Blocky notification sens every minute a notificaiton
assenzuid
Target OS: Raspberry Pi
Post by assenzuid » Saturday 02 June 2018 16:32
I've created below Blocky notification, but when it's triggerd I get every minute a notification and stops when value is below given %.
How to prevent this.
I want to send an email to multiple receivers.
SweetPants
Domoticz version: V4.9999
Re: Blocky notification sens every minute a notificaiton
Post by SweetPants » Saturday 02 June 2018 17:10
Did you set your blockly to 'time' triggered perhaps? That explains the 1 minute interval.
If you set it to 'device' it will only send a notification when the value changes and is above 30%. But it will keep sending notifications when the value keeps changing and is above 30%.
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
assenzuid
Post by assenzuid » Sunday 03 June 2018 22:51
Yes, it was set at 'all'.
I changed it to 'device', did you mean that wen the value rise above 30 and later to 40 it will send also a notification.
I only need one-time notification when the value rise above 30 and when the value is below 30 and later it will rise again I want also a new notifciation.
SweetPants
Post by SweetPants » Monday 04 June 2018 10:08
Yes
Then you have to add some extra logic that you already send a notification after the first time and reset that when getting below you threshold again.
Maybe take a look at dzVents https://www.domoticz.com/wiki/DzVents:_ ... _scripting , this gives you way more flexibility then blockly
mrf68
Domoticz version: 3.4834
Post by mrf68 » Tuesday 05 June 2018 9:19
Create a virtual switch, set it to On when sending the message and have the send message part check is the switch is On. If Off then send message. Check hum every minute. If hum < desired set virtual switch to Off.
Instead of a virtual switch you could use a uservariable.
