sensor type lighting 5 kangtai/cotech door contact
Sticz
Target OS: Raspberry Pi
Domoticz version: lastest
Post by Sticz » Tuesday 29 May 2018 14:34
He alle,
My cheap sensor type lighting 5 kangtai/cotech door contact connects automatically with rfxcom
But than it only shows last seen no other status change .. any suggestion what i can do to use the status within domoticz ?
https://www.aliexpress.com/item/Origina ... 77597.html
Sticz
Re: sensor type lighting 5 kangtai/cotech door contact
Post by Sticz » Tuesday 29 May 2018 17:20
May work around is:
call the sensor a switch.
If the sensor is triggered it can switch an ON status to OFF.
So I used the timer to "arm" the sensor ( switch to ON)
Once triggered the timer will go to OFF and set action (email etc )
Any other bright ideas ?
