Nefit Easy XMPP authentication failure
SweetPants
Domoticz version: V4.9701
Re: Nefit Easy XMPP authentication failure
Post by SweetPants » Sunday 10 June 2018 15:42
Does your firewall allow XMPP? (TCP 1880) to the outside world?
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (source)
Biarritz
Target OS: Raspberry Pi
Post by Biarritz » Sunday 10 June 2018 21:25
I'm not aware of the fact that my firewall/router is blocking this port.
I have used nefit easy for some time now but ran into this issue a few days ago.
No changes were made in my fireall recently.
Biarritz
Post by Biarritz » Tuesday 12 June 2018 15:27
Question, if my Nefit thermostat is connected to the internet is does this not mean that Domotixz should be able to do so as well?
There is no firewall blocking port 1880 that I'maware of and the Nefit app on my phone is working correct as well.
SweetPants
Post by SweetPants » Tuesday 12 June 2018 16:20
I'm not 100% sure what ports the easy-server is using, but I guess the same as the thermostat uses.
But your log of the easy-server signals an authorization issue using XMPP.
I have seen this one time before, but can't remember why this happened. Eventually I removed any reference to node, npm and easy-server and re-installed everything again.
