Temperature/Humidity sensor
Knibor
Target OS: OS X
Post by Knibor » Sunday 27 May 2018 16:02
I'm currently use a temp/humidity sensor "Philio Technology Corporation PH-PAT02-B.eu Multisensor 2in1+"
When I add this sensor in Domotics, I can read the temperature 22,0 and humidity 65%.
Now I want to switch "on" my pellet stove when temperature is below 24 degrees Celsius.
I tried this with "Blockly" but this is not working.
What do I wrong?
Can someone help me with this!
Schermafbeelding 2018-05-27 om 15.59.23.png (53.39 KiB) Viewed 1310 times
Xztraz
Target OS: Raspberry Pi
Re: Temperature/Humidity sensor
Post by Xztraz » Sunday 27 May 2018 17:57
have you set device as trigger?
something like this should work.
Joep123
Post by Joep123 » Sunday 27 May 2018 23:07
IF cannot be only a temperature. I always add a time, like "IF TIME is not 00:00"
Verstuurd vanaf mijn MI 5 met Tapatalk
Knibor
Target OS: OS X
Post by Knibor » Sunday 27 May 2018 23:45
Hi, I tried the example that you show me, but it doesn't work?
But...how to set the device as trigger?
Do you have an example for me!
Knibor
Target OS: OS X
Post by Knibor » Sunday 27 May 2018 23:48
Schermafbeelding 2018-05-27 om 23.47.36.png (68.94 KiB) Viewed 1259 times
I also tried to add a time, it doesn't work.
Xztraz
Post by Xztraz » Monday 28 May 2018 12:58
mrf68
Domoticz version: 3.4834
Post by mrf68 » Monday 28 May 2018 18:49
You’re using the If/Else If block, try the one without the blue square in the left upper corner.
Knibor
Target OS: OS X
Post by Knibor » Monday 28 May 2018 23:43
Hi, thanks a lot, it works now.
Schermafbeelding 2018-05-28 om 23.40.54.png (115.59 KiB) Viewed 1190 times
mmjumel5
Post by mmjumel5 » Tuesday 05 June 2018 12:16
Bonjour.
Je suis étudiant et débutant dans l'IoT.
Je voudrai savoir comment envoyer la température et l'humidité vers le serveur domoticz installé sur ma raspberry pi 3.
Si j'utilise un script python pour récupérer la température et l'humidité côté raspberry, comment envoyer ces paramètres à partir de l'IDE Arduino ?
Toute suggestion allant dans ce sens me sera utile.
Merci
Users browsing this forum: Bing [Bot] and 0 guests
