Python plugion: Reuse an ICMP connection
elgringo
Target OS: Raspberry Pi
Domoticz version: Left
Post by elgringo » Sunday 27 May 2018 9:31
I want to check if a certain deivce is online, ping it. The pinger.py example closed each ICMP connection since it uses multiple IP addresses
In the onheartbeat function I added
# check if TV is online
    if (self.icmpConnection == None):
      self.icmpConnection = Domoticz.Connection(Name="LG_ICMP", Transport="ICMP/IP", Protocol="ICMP", Address=Parameters["Address"])
      self.icmpConnection.Listen()
    else:
      self.icmpConnection.Send("PING")
But this don't seem to work. There is never a message send.
When I ping it form the shell the plugin received the reply and it handles them correct.
When detroying the connection and start a new one (the part in the if statement) if a ICMP message is received does work, but every time a new connection has to be created.
So the requestion: How can I ping on an existing ICMP connection
Secondly I also noticed the file handle count is increasing, so a network connection is not closed/ destroyed correctly.
Are there a basic examples with a ICMP connection (basic is simple ping to single node)?
elgringo
Re: Python plugion: Reuse an ICMP connection
Post by elgringo » Sunday 03 June 2018 8:03
Does anybody knows this? Or is it not possible?
I noticed a bugfix on releasing the sockets. But still don;t you if the ICMP 'connections' can be reused.
Dnpwwo
Post by Dnpwwo » Monday 04 June 2018 23:43
@elgringo,
The 'pinger.py' example that ships with Domoticz shows how to use the ICMP transport.
What platform are you using? I just tried this on Linux and it no longer works so I will need to troubleshoot it again.
elgringo
Post by elgringo » Sunday 10 June 2018 18:24
I am using Linux on a raspberry pi.
The pinger.py example does not reuse a connection. eg use the send command to re ping a device instead of using a new connection with the listen command.
I don't know if this is possible.
Dnpwwo
Post by Dnpwwo » Sunday 17 June 2018 6:35
@elgringo,
The ICMP connection functions a little differently depending on the platform you run it on. Normally the boost libraries Domoticz uses do a good job of protecting users from platform differences but not in this case for some reason. You may need to experiment a little.
There are a couple of patterns that worked when I tested this on different operating systems depending on what you want to achieve.
  • One thing to remember is that 'Send' starts a 5 second timeout for the connection which may get messed up if you don't wait for a response.
  • Listening on an ICMP connection will actually send a 'ping' for you (the 'listen' will fail on Windows if it doesn't for some reason)
  • If you open one connection and listen on it, on some platforms it will see all ICMP traffic (even returns from a command line ping outside of Domoticz) others platforms only return traffic to specific 'listen' address
