Roller shutter control
salopette
Target OS: Raspberry Pi
Domoticz version: V3.6882
Post by salopette » Saturday 26 May 2018 12:46
hello, I can not get it to control the blinds with a dummy switch.
My intention was that I do dummy as a selector and then stop level 10, 20, 30 40 times the blind stops.
But do not get it set up in Blockly.
Could help with someone?
astrapowerrr
Re: Roller shutter control
Post by astrapowerrr » Monday 28 May 2018 14:19
i am also curiuos how this could work.
i have a somfy sunscreen that just can open and close and has a stop command to stop when i want that.
percentage like 25% 50% and 75% would be nice to configure in time.
Egregius
Post by Egregius » Monday 28 May 2018 14:41
Create a shell script with the corresponding open/sleep/stop commands and execute those with the selector switch.
salopette
Post by salopette » Monday 28 May 2018 18:44
How do you do that?
Egregius
Post by Egregius » Monday 28 May 2018 20:26
You start by searching the wiki.
And then you create a script, for example: /home/pi/openblind99.sh
#!/bin/bash
curl -s 'http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=99&switchcmd=On'
sleep 4
curl -s 'http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=99&switchcmd=Stop'
make the script executable:
chmod +x /home/pi/openblind99.sh
add the script to the selector switch with the full path
scipt:///home/pi/openblind99.sh
salopette
Post by salopette » Monday 28 May 2018 20:36
Thank you! Did not understand it from the wiki, but your example is very helpful!
