MDAH and v3.9501 no connection to devices
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Target OS: Raspberry Pi
Re: MDAH and v3.9501 no connection to devices
Post by waaren » Tuesday 29 May 2018 12:21
opened issue https://github.com/empierre/MyDomoAtHome/issues/169 (was already reported as a domoticz issue)
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
epierre
Post by epierre » Tuesday 29 May 2018 12:22
Has this being identified by gizmocuz or is that a wanted behavior ?
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
vulbas
Post by vulbas » Tuesday 29 May 2018 12:43
thank you, I had not thought to put on the github MDAH
merci, je n'avais pas pensé à mettre sur le github MDAH
epierre
Post by epierre » Thursday 31 May 2018 16:06
fix done, package tonight, stay tuned !
epierre
Post by epierre » Thursday 31 May 2018 19:46
package 0.2.38 is out !
vulbas
Post by vulbas » Thursday 31 May 2018 20:32
I no longer have access to the MDAH page
pi@raspberrypi:~ $ curl http://192.168.1.225:3002/devices
curl: (7) Failed to connect to 192.168.1.225 port 3002: Connexion refusée
pi@raspberrypi:~ $ node --version
v4.2.2
pi@raspberrypi:~ $ npm --version
2.15.12
pi@raspberrypi:~ $ sudo service mydomoathome status
● mydomoathome.service - MDAH ISS Rest interface for Domoticz to Imperihome
   Loaded: loaded (/etc/systemd/system/mydomoathome.service; enabled; vendor pre
   Active: active (running) since Thu 2018-05-31 20:26:15 CEST; 7min ago
  Process: 3424 ExecStartPre=/bin/chmod 755 /run/mydomoathome (code=exited, stat
  Process: 3421 ExecStartPre=/bin/chown www-data:www-data /etc/mydomoathome/conf
  Process: 3418 ExecStartPre=/bin/chown www-data:www-data /run/mydomoathome (cod
  Process: 3415 ExecStartPre=/bin/mkdir -p /run/mydomoathome (code=exited, statu
 Main PID: 3427 (mydomoathome)
   CGroup: /system.slice/mydomoathome.service
           ├─3427 /bin/bash /usr/share/mydomoathome/bin/mydomoathome
           ├─3428 node /usr/local/bin/forever --minUptime 5000 --spinSleepTime 2
           └─4580 /usr/bin/node /usr/share/mydomoathome/app/mdah.js
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Module.require (module.js:366:17)
mai 31 20:33:35 raspberrypi MDAH[3427]:     at require (module.js:385:17)
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Object.<anonymous> (/usr/share/my
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Module._compile (module.js:435:26
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Object.Module._extensions..js (mo
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Module.load (module.js:356:32)
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Function.Module._load (module.js:
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Function.Module.runMain (module.j
mai 31 20:33:35 raspberrypi MDAH[3427]: error: Forever detected script exited wi
mai 31 20:33:38 raspberrypi MDAH[3427]: error: Script restart attempt #102
lines 1-23...skipping...
   Loaded: loaded (/etc/systemd/system/mydomoathome.service; enabled; vendor preset: enabled)
  Process: 3424 ExecStartPre=/bin/chmod 755 /run/mydomoathome (code=exited, status=0/SUCCESS)
  Process: 3421 ExecStartPre=/bin/chown www-data:www-data /etc/mydomoathome/config.json (code=exited, status=0/SUCCESS)
  Process: 3418 ExecStartPre=/bin/chown www-data:www-data /run/mydomoathome (code=exited, status=0/SUCCESS)
  Process: 3415 ExecStartPre=/bin/mkdir -p /run/mydomoathome (code=exited, status=0/SUCCESS)
           ├─3428 node /usr/local/bin/forever --minUptime 5000 --spinSleepTime 2000 --max-old-space-size=128 -a -l /var/log/mydomoathome/mdah.log /usr/share/mydomoathome/app/mdah.js
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Object.<anonymous> (/usr/share/mydomoathome/app/mdah.js:38:16)
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Module._compile (module.js:435:26)
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Object.Module._extensions..js (module.js:442:10)
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Function.Module._load (module.js:311:12)
mai 31 20:33:35 raspberrypi MDAH[3427]:     at Function.Module.runMain (module.js:467:10)
mai 31 20:33:35 raspberrypi MDAH[3427]: error: Forever detected script exited with code: 1
epierre
Post by epierre » Thursday 31 May 2018 21:03
right, dependency issue, I'm pushing 0.2.39 now
vulbas
Post by vulbas » Thursday 31 May 2018 21:21
pppeeerrrfffeeeccctttttttttt
thank you :D :D :D :D :D :D
epierre
Post by epierre » Thursday 31 May 2018 21:23
:D :D :D :D
scorp99fr
Post by scorp99fr » Thursday 31 May 2018 22:55
Wouhouuuu it works again very fine !!! :D
Thank you very much for your work :D
KingOfIce
Post by KingOfIce » Thursday 31 May 2018 23:15
I confirm it works on Synology too. Thanks a lot !
EdddieN
Domoticz version: 4.9700
Post by EdddieN » Wednesday 11 July 2018 0:53
Is this working again on the RPI? using 4.9700 and I get:
curl: (52) Empty reply from server
tried to install everything and start over as per https://github.com/empierre/MyDomoAtHome
node v: 4.2.2
npm v: 2.14.7
11101101 - www.machinon.com
epierre
Post by epierre » Sunday 15 July 2018 20:17
in 4.9785 it works fine for me, can you confirm ?
EdddieN
Post by EdddieN » Monday 16 July 2018 12:04
I installed on a spare RPI with 4.9700 and all working fine. I guess I must have some libraries broken.
Using much higher node and npm -v than stated on the instructions there
