Translate curl command to get UV data to URL Topic is solved
Target OS: Raspberry Pi
Post by waaren » Wednesday 23 May 2018 18:50
I want to add a virtual UV sensor to my domoticz environment and found https://www.openuv.io to get the data from.
My preference is to use a standard URL because I want to process the JSON return directly in dzVents without storing the result in an OS file first.
The command to get the JSON in curl is
curl -X GET 'https://api.openuv.io/api/v1/uv?lat=-51,11&lng=4,99' -H 'x-access-token: blablablablablablablablabla'
Does anyone know how to translate this into a regular url ?
I am also interested from which sites other forum members get their UV data from. Preferable with a JSON return
Thx in advance for any reaction
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
elmortero
Domoticz version: 3.9639
Re: Translate curl command to get UV data to URL
Post by elmortero » Thursday 24 May 2018 3:08
You cannot pass your token (apikey) to Openiv.io as a query string like with darksky for example.
As an alternative you can use io.popen
(sorry Dannybloe, I tried to pass the -H x-access-token with your asynchronous http requests but gave up on it :( )
Here is the script I came up with(dzvents):
		timer = { 'every 30 minutes' }
	execute = function(domoticz, triggerItem)
--check offset for DST/non-DST
--these are for timezone Brussels. change to match your timezone
	    local situation = os.date("%Z")
	    if situation == 'CET' then
	        offset = 1 --non-DST
        else offset = 2 --DST
       json = (loadfile "/home/root/domoticz/scripts/lua/JSON.lua")()  -- For Linux
       local token = 'xxxxxxxx'    -- fill in your key here
       local lat = 'xxxxx'	--latitude
       local lng = 'xxxxxx'	--longitude
       local config=assert(io.popen("curl -X GET 'https://api.openuv.io/api/v1/uv?lat="..lat.."&lng="..lng.."' -H 'x-access-token: '"..token))
       local location = config:read('*all')
       config:close()
       local response = json:decode(location)
    				uv = tonumber(response.result.uv)
    				uv_max = domoticz.utils.round((response.result.uv_max),0)
    				uv_max_time = response.result.uv_max_time
					--get hour and minutes only from time string
					local hora = tonumber(string.sub(uv_max_time, 12,13)) + offset --add offset for timezone and DST to hours
					local mins = string.sub(uv_max_time, 15,16)
					maxtime = tostring(hora..':'..mins) --combine to HH:MM
    				ozone = domoticz.utils.round((response.result.ozone),0)
    				print('\nCurrent UV value : '..uv)
					print('Highest UV value today: '..uv_max)
					print('Highest UV value at: '..maxtime)
					print('Current ozone value: '..ozone)
				-- update your sensors with aquired values here
Post by waaren » Thursday 24 May 2018 16:20
@elmortero, thx for the script. I cherry picked a little bit from it see my solution here but I only want aSync type of calls to external URL's or to OS functions that could cause a delay to the event system. I now made something with the use of a domoticz user variable. First part starts the curl in the background and second part (triggered by the updated uservar) reads the json return and update the virtual sensors / devices.
Again thanks for your reaction and script.
elmortero
Post by elmortero » Thursday 24 May 2018 17:15
That's what I want too :-)
But sometimes when it cannot be as it must be, it must be as it can.
EddyG
Domoticz version: 4.10252
Post by EddyG » Thursday 24 May 2018 19:26
My bad (syntax BUG). This works.
                        domoticz.openURL({
                                url = 'https://api.openuv.io/api/v1/uv?lat=<lat>&lng=<lon>',
                                method = 'GET',
                                callback = 'UV-data',
                                headers = { ['x-access-token'] = '<api-key>' },
And later to get the UV from the response:
 local UVvalue = item.json.result.uv
Regards,
Eddy
elmortero
Post by elmortero » Thursday 24 May 2018 22:51
Excellent, couldn't figure that one out last night..
Thanks a lot!
Post by waaren » Friday 25 May 2018 1:32
This works.
                        domoticz.openURL({
                                method = 'GET',
You are the man !
Thx
