Rain counter
tage
Target OS: Raspberry Pi
Rain counter
Post by tage » Tuesday 15 May 2018 14:20
Hi. Is it possible to script like this :
viewtopic.php?t=15616
But update a rain sensor instead of a general counter ?
I have connect a tipping bucket rain gauge to an esp and set it up as a switch (on/off) if set it up like this it dosen't matter if the esp lose power or reboot the counting is still works..
/ tage
elmortero
Domoticz version: 3.9639
Re: Rain counter
Post by elmortero » Tuesday 15 May 2018 15:15
tage
Re: Rain counter
Post by tage » Tuesday 15 May 2018 17:10
Thx. But I don't think I'm able to make a script from scratch. I was hoping I could modify one..
Re: Rain counter
Post by waaren » Tuesday 15 May 2018 19:44
Happy to get you started with a dzVents script but need some more info to work with;
Is my assumption correct that every time the bucket tips you send an On command to a domoticz switch ?
Do you do that via a json command or in another way ?
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
tage
Re: Rain counter
Post by tage » Tuesday 15 May 2018 20:43
exacly every time the bucket tips it pass the magnet and make it "on" for a short time in the tipping moment or "off" it is possible to change.
on the esp (wemos d1) im using esp easy (letscontrolit) and using "Domoticz HTTP" im assume it is json.
Re: Rain counter
Post by waaren » Tuesday 15 May 2018 22:33
Hope this dzVents script will get you going.
    on = {  timer =                { "at 00:01" },
            devices = {             "ESPTestSwitch"     } },                             -- Your switch device triggered by ESP bucket full
            logging = {     level = domoticz.LOG_DEBUG,                                  -- INFO, ERROR or DEBUG
                            marker = "ESP test" },                                            --
    execute = function(dz, trigger)
        local rainDevice    = dz.devices("ESPTestRain")                                     -- Your (virtual) rain device
        local rainSwitch   = dz.devices("ESPTestSwitch")                                     -- Your (triggered by bucket full) switch
        local rainmm        = 2        -- find out what 1 bucket full means in terms of mm
        local rainTotal     = 0
        local timeSlice     = math.min( (rainDevice.lastUpdate.secondsAgo / 3600), 10) -- at least 1 bucket  in 10 hours
        local rainAmountHour = dz.utils.round((rainmm / timeSlice),1)
        -- Calc raintotal and reset raintotal at midnight
        if trigger.isTimer then
            rainDevice.updateRain(dz.utils.round(rainDevice.rainRate,0),0)                     -- reset rainTotal
            rainSwitch.switchOff().silent()
            dz.log("Reset raintotal to 0",dz.log_DEBUG)
            rainTotal = dz.utils.round((rainmm + rainDevice.rain),1)
            rainDevice.updateRain(rainAmountHour,rainTotal)
            dz.log("One bucket full ==>> updating raindevice. rainrate: " .. rainAmountHour .. " mm/hr, " .. rainTotal .." mm in total today "  ,dz.log_DEBUG)
tage
Re: Rain counter
Post by tage » Wednesday 16 May 2018 6:06
thx !
got some trouble and this is what the log says :
2018-05-16 05:53:27.027 Error: dzVents: Error: ESP test: An error occured when calling event handler rain_bucket
2018-05-16 05:53:27.027 Error: dzVents: Error: ESP test: ...moticz/scripts/dzVents/generated_scripts/rain_bucket.lua:16: attempt to index field 'utils' (a nil value)
i think i have edit and change that is needed...
/ tage
Re: Rain counter
Post by waaren » Wednesday 16 May 2018 7:27
thx !
got some trouble and this is what the log says : attempt to index field 'utils' (a nil value)
/ tage
What is your domoticz / dzVents version ?
the isTrigger method was introduced in dzVents 2.4.0
the utils round function was introduced in dzVents 2.4.0
the silent() option to switchOff() function was introduced in dzVents 2.3.0
if you really cannot update to a domoticz Beta version with dzVents 2.4.0 or higher you could try the script below where I worked around the new stuff introduced in later dzVents versions. But much better to go a later domoticz with all the new great dzVents stuff in.
    execute = function(dz, trigger, triggerInfo)
        function round(num, numDecimalPlaces)
            return tonumber(string.format("%." .. (numDecimalPlaces or 0) .. "f", num))
        local rainSwitch    = dz.devices("ESPTestSwitch")                                     -- Your (virtual) rain device
        local rainFactor    = 100                                                               -- To get a realistic mm/hr value (adjust to your needs)
        local rainTotal     = 0
        local rainAmountHour =round((rainmm / timeSlice * rainFactor),1)
            if triggerInfo.type == dz.EVENT_TYPE_TIMER then
                rainDevice.updateRain(round(rainDevice.rainRate,0),0)                     -- reset rainTotal
            elseif rainSwitch.state ~= "Off" then
                rainTotal = round((rainmm + rainDevice.rain),1)
tage
Re: Rain counter
Post by tage » Wednesday 16 May 2018 9:38
Thx. The last one seems to work I have to do some test tonight.
My domoticz Version: 3.8153
Guess it is the latest stable.
I have not try the beta and don't know how stable they are that's why I'm on stable versions....
/ tage
Re: Rain counter
Post by waaren » Wednesday 16 May 2018 10:08
Just backup your current version, directories and most important database (and make sure you can restore :D ) before you install the latest Beta and enjoy all new features ..
tage
Re: Rain counter
Post by tage » Wednesday 16 May 2018 16:52
Aah I'm maybe give it a try.
It act little strange when set the rain mm to 1 (one bucket is 1mm)
And rain factor I'm not sure what value to set. Gonna do some more test later
tage
Re: Rain counter
Post by tage » Wednesday 23 May 2018 4:55
I just found that the script is counting both on and off.. the rain gauge is making the on switch and goes back to off again.
possble to make the script only count "on'" command ?
/ Tage
Re: Rain counter
Post by waaren » Wednesday 23 May 2018 8:27
/ Tage
@tage,
the line
should ensure the script only counts if the switch is set to a state not equal to "Off".
In later versions of dzVents (> 2.2) you would change the line
to
to prevent the triggering of the script if the rainSwitch is set to "Off".
You could add
dz.log("Script triggered by rainSwitch state: " .. rainSwitch.state,dz.log_DEBUG)
just above the switchOff() line to see in the log when the counting part of the script is executed.
