Xiaomi Cube - XiaomiGateway: unhandled model: sensor_cube.aqgl01
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
MarFan
Target OS: Raspberry Pi
Post by MarFan » Tuesday 15 May 2018 10:10
Version: 3.9389 (beta)
Platform: Pi
Plugin/Hardware: Pi
Description: added (on a working GW) the (new arrived) cube.
In Mi Home, everything is working,
In the log I see the error message : XiaomiGateway: unhandled model: sensor_cube.aqgl01
No device is created.
MarFan / NL / 3x RasPi / RfXcom / RfLink / S0PCM-5 / P1
marigo
Domoticz version: V3.9527
Re: Xiaomi Cube - XiaomiGateway: unhandled model: sensor_cube.aqgl01
Post by marigo » Tuesday 15 May 2018 10:38
Exact same problem here. Found https://github.com/Danielhiversen/PyXia ... /issues/67 , but don't know how to manually add this.
MarFan
Post by MarFan » Tuesday 15 May 2018 10:54
Thanks,
I think we have to wait for new beta version with this included ?
marigo
Post by marigo » Tuesday 15 May 2018 11:13
Yep, think so too. Just updated to last beta, but still no luck.
1981nick1981
Post by 1981nick1981 » Wednesday 16 May 2018 20:16
Yesterday I added the model to domoticz on Github. Does it work now? Can not check it.
See: https://github.com/domoticz/domoticz/pull/2393
MarFan
Post by MarFan » Thursday 17 May 2018 10:01
I updated to version 9445, but no new device
Also the error message does not appear anymore,
I do have [Accept new Hardware Devices ] enabled
1981nick1981
Post by 1981nick1981 » Thursday 17 May 2018 18:47
I do indeed have the same problem. The error message in the log is gone, but it can not be found in the list of devices. Is there someone who knows how to solve this?
marigo
Post by marigo » Thursday 17 May 2018 20:13
Updated to the last beta and also no log message anymore, but also no cube.
Tried to remove the cube and add it again; still no luck.
Any suggestions?
1981nick1981
Post by 1981nick1981 » Friday 18 May 2018 21:01
The problem is still present see the presence of the cube in the log but in devices it is still not visible.
2018-05-18 20:49:09.879 {"cmd":"heartbeat","model":"sensor_cube.aqgl01","sid":"****","short_id":****,"data":"{\"voltage\":2975}"}
Link to Github xiaomi location domoticz:
https://github.com/domoticz/domoticz/bl ... ateway.cpp
marigo
Post by marigo » Monday 28 May 2018 16:22
Installed last beta today "9527" but the new cube isn't recognized by domoticz.
Can it be implemented by the developers?
joostnl
Post by joostnl » Monday 28 May 2018 17:41
Could we owners supply some debug for an smarter developer?
1981nick1981
Post by 1981nick1981 » Monday 28 May 2018 20:08
The same problem exists in home-assistant and would have to do with the new "Gateway LAN communication protocol V2.0" This is not supported by gateway v2 so the signals are not sent over the network and are only available in the mi home app. At the moment the cube can only be read through solutions such as Zigate and zigbee2mqtt. The Air Conditioning Controller can also handle this signal.
Link to discussion Github:
https://github.com/home-assistant/home- ... pull/14393
marigo
Post by marigo » Monday 28 May 2018 20:38
Ok, so options are:
Buy a Aqara gateway 3 or a Zigate stick or the hardware needed for zigbee2mqtt?
Is it just not possible for Mi/Aqara to support the V2 protocol via a firmware update?
1981nick1981
Post by 1981nick1981 » Monday 28 May 2018 21:02
I do not know. I have now ordered the components to build the zigbee2mqtt solution. Hopefully here is someone with programming skills who knows the answer.
marigo
Post by marigo » Monday 28 May 2018 21:11
Ok, check!
I just wait a few days/weeks to think about it and to do some investigation.
Thank you for support!
dragstere42
Post by dragstere42 » Monday 28 May 2018 22:51
I found it on the jeedom plugin:
Version du 25 mai 2018
Ajout de la nouvelle version du Cube Aqara (actuellement le firmware de la gateway ne renvoit pas les infos, uniquement la batterie)
It said that for now the gateway firmware version only send batterie information for aqua cube.
Maybe we just need to wait a new gateway version for aqua cube ?
I will try to contact xiaomi.
whatisk
Domoticz version: 3.9224
Post by whatisk » Thursday 14 June 2018 12:50
Did you get in contact with Xiaomi and has there been any response?
I just received a Xiaomi Aqara Cube today. I thought I had read somewhere it was compatible but obviously not.
I'm even finding it very sluggish through the MiHome App (China server) responding to any actions. To the point where it isn't really useful in setting up to do anything.
Frucoboti
Post by Frucoboti » Wednesday 04 July 2018 22:18
Any news about this?
RezzZ
Post by RezzZ » Tuesday 24 July 2018 14:31
hmm I thought the cube was supported as it is listed in the compatible devices list but I guess now that wasn't the aqara cube..
the old cube is working according to this thread:
http://www.domoticz.com/forum/viewtopic.php?t=16199
hope support can be added soon.
salopette
Domoticz version: V3.6882
Post by salopette » Tuesday 07 August 2018 18:10
is there anything new about the Aqara Cube?
Users browsing this forum: tezzlicious and 9 guests
