Lua_Parser scripts - global tables
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
boe666
Target OS: Raspberry Pi
Post by boe666 » Monday 14 May 2018 9:54
Version:3.9439
Platform:Pi2
I have no access to otherdevices_svalues and other global tables - are empty.
The example from wiki:
function LogVariables(x,depth,name)
for k,v in pairs(x) do
if (depth>0) or ((string.find(k,'device')~=nil) or (string.find(k,'variable')~=nil) or
(string.sub(k,1,4)=='time') or (string.sub(k,1,8)=='security')) then
if type(v)=="string" then print(name.."['"..k.."'] = '"..v.."'") end
if type(v)=="number" then print(name.."['"..k.."'] = "..v) end
if type(v)=="boolean" then print(name.."['"..k.."'] = "..tostring(v)) end
if type(v)=="table" then LogVariables(v,depth+1,k); end
-- call with this command
LogVariables(_G,0,'');
Print NOTHING.
Is it error or not ? Will be fixed ?
boe666
Re: Lua_Parser scripts - global tables
Post by boe666 » Wednesday 16 May 2018 9:54
Nobody can say something about this problem? Without access to global tables in lua_parses - domoticz can't be functional.
dannybloe
Post by dannybloe » Saturday 19 May 2018 9:16
Use dzVents and you don't have to do all of this and still code in Lua.
Users browsing this forum: No registered users and 10 guests
