Heed help with RGB
Resperro
Target OS: Raspberry Pi
Heed help with RGB
Post by Resperro » Sunday 13 May 2018 13:29
Hi, I'm new here, I'm trying to connect the RGB strip to the system. Dimmer was able to connect. But how to change the color, the color itself was sent to the ESP. As well as the dimmer value. I need HEX as in the log.
2018-05-13 11:18:43.084 setcolbrightnessvalue: ID: d, bri: 61, color: '{m: 3, RGB: caffd3, CWWW: 0000, CT: 0}'
Something similar to http://" .. IP .. "/?RGB=HEXvalue
or rgb like R=RR G=GG B=BB
Dimmer I use:
DomDevice = 'Bed_rgb_light';
IP = '192.168.1.40';
if devicechanged[DomDevice] then
         DomValue = otherdevices_svalues[DomDevice];
         CalcValue = DomValue;
         commandArray['Variable:Bed_rgb_light_var'] = tostring(CalcValue);
--         print ("dimm Level = "..uservariables['Bed_rgb_light_var']);
   runcommand = "curl http://" .. IP .. "/?A=" .. CalcValue .. " ";
   os.execute(runcommand);
print("PWM calculated value= "..CalcValue);
Is this possible in Domoticz?
morilm
Target OS: OS X
Re: Heed help with RGB
Post by morilm » Sunday 27 May 2018 9:58
Hi... Since a few weeks there has been changes on the RGB and now it's possible to read the color values using JSON. See example bellow how to get values for RGB colors
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local acolor = " "
ab='curl "http://192.168.1.101:8080/json.htm?type ... '..led_idx..'"'
local jsondata = assert(io.popen(ab))
local jsondevices = jsondata:read('*all')
jsondata:close()
local jsonCPM = json:decode(jsondevices)
local acolor=jsonCPM.result[1].Color
print (acolor)
If you wish to decode the color reply from Json you need to do some magic to strip the values from the color table
acolorj=acolor:gsub("}",",}")
aacolor={}
for k,v in acolorj:gmatch('"(.-)":(.-),') do
aacolor[k]=v
print(k,v)
full info here: https://www.domoticz.com/wiki/Domoticz_ ... emperature
Hope some day LUA properties for switches will be updated to get the info directly without using JSON as part of the otherdevices_svalues for example.
regards,
Miguel
