EventSystem: reset all events...
fabiorodo
Target OS: Raspberry Pi
Post by fabiorodo » Sunday 13 May 2018 12:02
after using a domoticz on rpi just for danfoss (with blocky events) on heaters I decided to add more pieces.
I started with a fresh install but every try on events gives me:
and nothing happens.
I tried several tests mostly really easy like
if time= xx:xx
then turn on light / close shutter
write xxx on log
Right now I have the last beta on rpi3 V3.9426
connected to domoticz I have:
a xwave system with multiple fgr222 a fibaro multisensor and the danfoss
a xiaomi gateway with temperature and leak sensors
a hue hub with mixed hue and tradfri lights.
any suggestions?
what should I check?
cogliostrio
Re: EventSystem: reset all events...
Post by cogliostrio » Saturday 19 May 2018 10:35
This log message only tells you that the eventsystem has been restarted, because you have saved a new event in the editor.
Can you switch the system manually from the web interface?
Posting your blockly will probably help as well.
fabiorodo
Post by fabiorodo » Monday 21 May 2018 18:36
thank you for your reply.
this is the blocky:
FireShot Capture 20 - CasaErreTi - http___192.168.178.44_8080_#_Events.png (14.45 KiB) Viewed 1000 times
the event is active and saved.
scrivania is a light switch but i also tried several others.
when i check the current status i get this:
Error getting current states, Is the Eventsystem Enabled?
the boxes in settings are unchecked so should be enabled.
any help is more than welcome.
f
SweetPants
Domoticz version: V4.9999
Post by SweetPants » Monday 21 May 2018 19:28
Are you sure that means enabled? They should be green
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
lmet
Domoticz version: v4.9700
Post by lmet » Monday 21 May 2018 19:44
Under Setup->Settings->Others, Is the EventSystem enabled ?
fabiorodo
Post by fabiorodo » Monday 21 May 2018 23:22
Hi to all,
this is what I have...
I found different pics in the forum.
but with both chrome and firefox in linux mint i get this.
FireShot Capture 24 - CasaErreTi - http___192.168.178.44_8080_#_Setup.png (23.69 KiB) Viewed 971 times
thanks for support
f
SweetPants
Post by SweetPants » Tuesday 22 May 2018 12:59
Are you sure you are running V3.9426? Then dzVents should be V2.4.5. I think you still have a application cache problem. Please clear your browser and application cache first (both are different things)
fabiorodo
Post by fabiorodo » Sunday 27 May 2018 18:38
Hi All,
thanks for your suggestions. I solved using Opera from mobile. even if I deleted the browser cache many times something was going wrong. events where disabled (in firefox and chrome the box was really confusing). right now I am trying to clean the app cache.
Thanks again
SweetPants
Post by SweetPants » Tuesday 29 May 2018 7:41
Hi All,
Thanks again
As said before you should clear your browser and application cache. The application cache is holding the old .js scripts hence the old data you see
Users browsing this forum: Bing [Bot] and 3 guests
