EventSystem: reset all events...
fabiorodo
Target OS: Raspberry Pi
Post by fabiorodo » Sunday 13 May 2018 12:02
after using a domoticz on rpi just for danfoss (with blocky events) on heaters I decided to add more pieces.
I started with a fresh install but every try on events gives me:
and nothing happens.
I tried several tests mostly really easy like
if time= xx:xx
then turn on light / close shutter
write xxx on log
Right now I have the last beta on rpi3 V3.9426
connected to domoticz I have:
a xwave system with multiple fgr222 a fibaro multisensor and the danfoss
a xiaomi gateway with temperature and leak sensors
a hue hub with mixed hue and tradfri lights.
any suggestions?
what should I check?
cogliostrio
Re: EventSystem: reset all events...
Post by cogliostrio » Saturday 19 May 2018 10:35
This log message only tells you that the eventsystem has been restarted, because you have saved a new event in the editor.
Can you switch the system manually from the web interface?
Posting your blockly will probably help as well.
fabiorodo
Post by fabiorodo » Monday 21 May 2018 18:36
thank you for your reply.
this is the blocky:
FireShot Capture 20 - CasaErreTi - http___192.168.178.44_8080_#_Events.png (14.45 KiB) Viewed 808 times
the event is active and saved.
scrivania is a light switch but i also tried several others.
when i check the current status i get this:
Error getting current states, Is the Eventsystem Enabled?
the boxes in settings are unchecked so should be enabled.
any help is more than welcome.
f
SweetPants
Domoticz version: V4.9895
Post by SweetPants » Monday 21 May 2018 19:28
Are you sure that means enabled? They should be green
Ubuntu 16.04.3 LTS, Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.2.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
lmet
Domoticz version: v4.9700
Post by lmet » Monday 21 May 2018 19:44
Under Setup->Settings->Others, Is the EventSystem enabled ?
fabiorodo
Post by fabiorodo » Monday 21 May 2018 23:22
Hi to all,
this is what I have...
I found different pics in the forum.
but with both chrome and firefox in linux mint i get this.
FireShot Capture 24 - CasaErreTi - http___192.168.178.44_8080_#_Setup.png (23.69 KiB) Viewed 779 times
thanks for support
f
SweetPants
Post by SweetPants » Tuesday 22 May 2018 12:59
Are you sure you are running V3.9426? Then dzVents should be V2.4.5. I think you still have a application cache problem. Please clear your browser and application cache first (both are different things)
fabiorodo
Post by fabiorodo » Sunday 27 May 2018 18:38
Hi All,
thanks for your suggestions. I solved using Opera from mobile. even if I deleted the browser cache many times something was going wrong. events where disabled (in firefox and chrome the box was really confusing). right now I am trying to clean the app cache.
Thanks again
SweetPants
Post by SweetPants » Tuesday 29 May 2018 7:41
Hi All,
Thanks again
As said before you should clear your browser and application cache. The application cache is holding the old .js scripts hence the old data you see
