Master/slave setup, devices not appearing on master
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
bramski
Post by bramski » Friday 11 May 2018 9:25
Version: 3.9415
Platform: Raspberry Pi
Plugin/Hardware: Domoticz - Remote server
Description:
I have bought a new Raspberry Pi 3b+ to act as a slave to my main domoticz instance. I want to get temperature / moisture reading from Mi Flora sensors (which are located in the garden) to the master.
However I don't see any devices from the slave in the devices list on master. No errors in the logs.
- I have created a seperate user on the slave "domoticz_master"
- Add new hardware of type "Domoticz - Remote server" and setup the correct IP and credentials.
- In the logs on master I see "Domoticz: TCP connected to: 192.168.178.123:6144", which is the correct IP/port
- On the slave I tried to set the specific devices with the "set devices" button.
- Both Raspberry Pi's are of model 3B+, and both are running v3.9415 of Domoticz.
- Rebooted both devices multiple times.
Anything else I can try / how can I debug this further?
felix63
Target OS: Raspberry Pi
Domoticz version: 3.8275
Re: Master/slave setup, devices not appearing on master
Post by felix63 » Friday 11 May 2018 10:45
What do you mean by '- On the slave I tried to set the specific devices with the "set devices" button'?
And did you check if 'Allow new devices' is on the Master?
bramski
Post by bramski » Friday 11 May 2018 10:59
Thanks for your answer. Yes I have "Accept new Hardware Devices" checked on master.
I mean on the slave in the edit users screen. You have a button "set devices" where you can set specific devices to be shared. Didn't have anything enabled there which should allow ALL devices according to the docs. Just to be sure I selected all available devices on the slave, but this didn't help.
gielie
Domoticz version: latest β
Post by gielie » Monday 14 May 2018 10:15
I have the same problem, my master domoticz is not showing any devices from my slave device, this is a pain in the ass for a long time. I set everything according to the wiki, it is connected to the slave according the log but no switches appear.
- Vision ZU1401 USB Stick
- Aeotec MultiSensor 6
- FIBARO FGS222
- FIBARO FGWPE Wall Plug
- Everspring AN157
- Neo CoolCam Power plug
- Neo CoolCam PIR Sensor
- Popp Smoke Detector
- Toon
- Kodi Media Server
ThaBoo
Post by ThaBoo » Tuesday 22 May 2018 23:09
Version: 3.9462
Platform: Raspberry Pi 3 (master) / Raspi Zero W (slave)
Description:
Same issue here, with similar purpose and setup as @bramski: the goal is bridging the distance to the bluetooth based Miflora sensors with a slave domoticz device. I tried everything mentioned above, so this problem seems to be repeatable.
Note that being a raspi zero W, the slave device is connected trough wifi.
On the slave the logfile shows
2018-05-22 22:31:38.800 Accepting shared server connections via MyDomotiz (see settings menu).
2018-05-22 22:31:38.802 Starting shared server on: :::6144
2018-05-22 22:31:38.805 TCPServer: shared server started...
2018-05-22 22:54:50.861 Incoming Domoticz connection from: xxx.yyy.zzz.aaa
On the master the logfile shows
2018-05-22 22:54:43.978 Domoticz: TCP connected to: xxx.yyy.zzz.bbb:6144
But nothing actually happens.
Aditionally, my master instance on the raspi 3 has quite some active devices but a CPU load of under 15% and memory use under 60%. The load on the raspi zero W slave is 30% (it is running a webcam as well) and memory use under 60% as well.
Any suggestion how to solve this is more than welcome!
Domoticz, Raspberry Pi, RFXCom, Plugwise Stretch & Smile, KlikaanKlikuit, EQ3 Max!, Foscam, Harmony Hub, Oregon Scientific
Siewert308SW
Post by Siewert308SW » Thursday 24 May 2018 23:25
Something aint right indeed.
Today i wanted to setup a Bluetooth relay.
I wanted to put my old rpi-b at the addict and look for bluetooth devices just to cover the area a bit more for devices presence detection.
All went well and motherboard sensors where instantly added to the master.
Then i added my Bluetooth detection plugin.
No of those where seen by the master so i created three dummy switches in the slave.
Only one dummy is seen at the master and when i switch/toggle all three dummy devices on the slave ON/OFF then that device on the master also switches no matter what dummy i toggle.
So master sees one Dummy device from slave while there are three and reacts on all dummy devices on the slave.
No additional devices are created.
Domoticz Version....: V3.9469 - beta
Domoticz Hash.......: dbf72441 - 2018-05-22 20:17:01
RPi Model...........: Raspberry Pi 3 Model B Rev 1.2
OS Release..........: Raspbian 8.0 (jessie)
Kernel..............: Linux 4.14.42-v7+ armv7l
Setup:
- RPi3 - PIco HV3.0A / Domo Beta 3.9XXX / RFXtrx433E / Aeotec Gen5
- RPi3 - PIco HV3.0A / PiHole / PiVPN / NAS / Print Server
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
MyDomoticz scripts: @GitHub
PIco UPS Toolkit: @GitHub
l00pz
Post by l00pz » Monday 11 June 2018 12:43
It looks like the Master / Slave Setup isn't working for Devices using the Python Plug-in system. I also created a Master / Slave Setup for my Python Plug-ins, but all Devices using these (Sonos + Denon / Marantz) Plug-ins aren't showing up in the Master. Dummy Devices do show up, so the connection is working. I use the same Python + Domoticz version on both devices, but to no avail. I created an GitHub issue for this.
Siewert308SW
Post by Siewert308SW » Monday 11 June 2018 14:13
Same for dummy devices.
It's because the device ID and hardware type is the same.
Found out when I made several dummies with different ID and same plugins but amended the device in in py files.
Don't know how to resolve this unfortunately
Setup:
- Youless Elec&Gas
- FI9803P Cams
- KD101 detectors
- Zwave & KaKu
