Domotic.Log method for python plugin framework and domoticz log levels
EscApe
Target OS: Raspberry Pi
Domoticz version: v3+beta
Post by EscApe » Thursday 10 May 2018 13:08
I'm running the domoticz service with -loglevel 1, which should show error and status messages. With this setting anything from within a python plugin except Domoticz.Error is ignored. Even when i set the plugin to debug mode "Domoticz.Debugging(1)".
Is there a way to generate a status message from a python plugin, so they will show with -loglevel 1? Or could different log levels be implemented for python plugins?
Use cases:
My Presence detection plugin logs when devices leave or arrive. I would like to see these messages in my log, but i do not want to enable the overall -loglevel 0 for domoticz, because that will flood my log with events from energy meters (P1), z-wave devices and other less important information.
If i (purposely) enable debug mode on a plugin i would like to see debug logging, regardless of the overall domoticz log setting.
Dnpwwo
Re: Domotic.Log method for python plugin framework and domoticz log levels
Post by Dnpwwo » Sunday 13 May 2018 7:12
@EscApe,
Couple of things, "Domoticz.Debugging(1)" is pretty verbose these days but the call now accepts a mask that will allow you to select what you see.
I'm reluctant to ignore things like the domoticz loglevel setting because one of the things I wanted to achieve with the plugins was to make them indistinguishable from either C++ brethern.
I added a 'Status' function to the Python API today (see https://www.domoticz.com/wiki/Developin ... llable_API) which may give you what you want.
EscApe
Post by EscApe » Sunday 13 May 2018 13:09
@Dnpwwo,
That's exactly what i was asking for (or at least tried to explain;-)). Just compiled and modified my plugin, and its working like a charm.
Users browsing this forum: No registered users and 3 guests
