Xiaomi RGB Gateway blocks other switches
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
askold
Target OS: Raspberry Pi
Post by askold » Sunday 06 May 2018 4:52
Version: 3.9389 and previous
Platform: Raspberry Pi
Plugin/Hardware: Xiaomi Gateway
Hi, all!
I'm just studying.
In this configuration
all works good
but if I add also "Xiaomi Gateway Volume", I see only this
and if I add also "Xiaomi RGB Gateway", I see nothing: "No Lights/Switches found or added in the system..."
In the "devices" tab all devices are works.
prudencepetitpas
Re: Xiaomi RGB Gateway blocks other switches
Post by prudencepetitpas » Saturday 12 May 2018 23:36
Hi there,
No help for the thread but just to say that you are not the only one, i have the same problem ...
ilfavi
Domoticz version: V3.9443
Post by ilfavi » Wednesday 16 May 2018 10:40
I think I have the same problem here (Version: 3.9443 on raspi).
There are no errors in the log and everything is working but the Switches page is empty.
ilfavi
Post by ilfavi » Wednesday 16 May 2018 11:49
After some forum searching I found this solution:
backup database
stop domoticz server
remove folder /home/pi/domoticz
remove folder /etc/domoticz
install domoticz ( sudo curl -L install.domoticz.com | bash )
restore database
items are back
update to beta
items are still there
askold
Post by askold » Thursday 17 May 2018 16:24
Unfortunately, I can not use this solution, because on my Raspberry Pi the stable version does not start. (error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory)
I tried to use windows version of domotics, but there is no such problem in either stable or beta version. But with the same file domoticz.db, with which there are no problems in the windows version, in the raspberry version the problem present.
Users browsing this forum: tezzlicious and 8 guests
