Can’t open blocky settings anymore page crashes
astrapowerrr
Post by astrapowerrr » Sunday 29 April 2018 22:06
Hi when I open the settings to make blocky.
I get a white page something went wrong.
I deleted cache in chromium but no luck.
Any ideas here?
The pi is my only computer at home.
Only iOS devices. But to small to work with blocky.
I’m running latest beta.
When I am at work and I log in I can use blocky.
Last edited by astrapowerrr on Sunday 29 April 2018 22:06, edited 1 time in total.
SweetPants
Domoticz version: V3.9501
Re: Can’t open blocky settings anymore page crashes
Post by SweetPants » Monday 30 April 2018 19:38
You said you cleared the cache, but did you also clear the "app cache"? Those are two separate things.
Ubuntu 16.04.3 LTS on Intel NUC, MySensors 2.3.0-alpha, Pro Mini 3.3/8M RFM69(HW), ESP8266 (SDK2.1.0), Sonoff, RFLink, RFXcom, MQTT, NodeRed, Domoticz Beta (from source)
astrapowerrr
Post by astrapowerrr » Monday 30 April 2018 21:39
Hi.
No did not do that.
But now I did and still no solution.
I used chrome://appcache-internals/
And I used ctrl f5.
I see it for a split second and then the white page.
All other menus I tried do work as normal.
One thing I noticed the blue pop up that is refreshing cache is not leaving. I left it for 15 min or so. But it stayed. Clicked on it and now it’s gone.
astrapowerrr
Post by astrapowerrr » Wednesday 02 May 2018 9:41
what should i try? Stil not working.
astrapowerrr
Post by astrapowerrr » Sunday 20 May 2018 21:18
astrapowerrr wrote:what should i try? Stil not working.
Nobody??
Target OS: Raspberry Pi
Post by waaren » Sunday 20 May 2018 22:17
My approach would be to:
Stop domoticz
Backup your current domoticz environment and make sure you can restore
Keep scripts, plugin, backup and Config subdirs and remove everything else
Re install domoticz restore your backup domoticz.db and do an ./updatebeta
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave , dzVents 2.4.n, Amazon echo
SweetPants
Post by SweetPants » Monday 21 May 2018 9:29
Try another browser perhaps?
astrapowerrr
Post by astrapowerrr » Thursday 24 May 2018 22:43
Tried to install but pi is not my best computer to work with.
Can’t get a new browser installed.
Did try but can’t get it working...
To much noob for that I think.
astrapowerrr
Post by astrapowerrr » Thursday 24 May 2018 22:44
waaren wrote:My approach would be to:
Stop domoticz
Before I try this... than I must be really stuck!!
Post by waaren » Friday 25 May 2018 1:29
I understand that it could look a bit frighting but if you use domoticz on a day to day basis, it is my strong believe that you need a working backup and tested restore solution anyway and especial if you are running a beta version then a test environment is almost a must have.
On my test PI the approach I describe in my previous post takes less than 10 minutes and give me the peace of mind that I can rebuild my production system when shit hits the fan. :D
Have fun !
astrapowerrr
Post by astrapowerrr » Friday 25 May 2018 10:25
I understand.
So I make every 2 weeks a copy of the sd card. On 3 different cards...
SweetPants
Post by SweetPants » Friday 25 May 2018 14:53
You can also use (linux) dd to copy the entire image to your machine, no need for extra SD cards. When one image crashes, just dd it back to the SD card. This is what I do with my RPI3 firewall and MySensors Gateway.
Users browsing this forum: No registered users and 4 guests
