-sslcert parameter ignored?
Doomic
Post by Doomic » Thursday 26 April 2018 9:46
Version: 3.8153
Platform: Ubuntu 16.04.3
i am trying to implement another ssl certificate.. i know there are a lot of questions about it, but can't find my situation.
My problem is that it looks like -sslcert is ignored in the startup script.
for testing purpose, i renamed server_cert.pem to server_cert_test.pem. and edited the sh script (see below)
restart domoticz... but website is not running... in log there is no "TCPSERVER: shared server started...".
next i renamed file back to server_cert.pem, but kept the sh script the same (as below).. restart domoticz.. and now the site is running (including the log of the TCPServer started).
What am i missing, is it still supported the sslcert parameter? where to look?
DAEMON=/usr/domoticz/$NAME
DAEMON_ARGS="-daemon"
DAEMON_ARGS="$DAEMON_ARGS -www 0"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 10003"
DEAMON_ARGS="$DAEMON_ARGS -sslcert /usr/domoticz/server_cert_test.pem"
DAEMON_ARGS="$DAEMON_ARGS -log /usr/domoticz/log.txt"
DAEMON_ARGS="$DAEMON_ARGS -syslog"
niki_lauda
Target OS: Raspberry Pi
Re: -sslcert parameter ignored?
Post by niki_lauda » Thursday 26 April 2018 20:13
My line =
"DAEMON_ARGS="$DAEMON_ARGS -www 8080 -loglevel=1 -sslwww 443 -sslcert /home/pi/domoticz/letsencrypt_server_cert.pem"
Doomic
Post by Doomic » Monday 30 April 2018 15:06
combined -sslwww and -sslcert at 1 line, now it works.
don't understand whats different between one line and splitsing it to two lines...
next i want to include the pem file that is automaticly generated by Webmin letsencrypt... Won't work... but thats another issue for another time.
thanks for the help
rrozema
Post by rrozema » Sunday 03 June 2018 20:55
Did you add the dhparams in the .pem file too? I missed that part at first too. Its in the very bottom of the instructions at http://www.domoticz.com/wiki/Native_sec ... ts_Encrypt how to do that. You need to generate the dhparams.pem file only once, then have it added every time in the script to put your <your certificates>.pem file together.
