Save detailed data over 24 hours
albercola
Post by albercola » Wednesday 04 April 2018 23:11
Hi everyone,
I have a Raspberry 3 that I use to record different temperature of a boiler of mine.I can't find a detailed/basic guide regarding how to save in a separate database ALL daily data (with 5 min interval) before they are overwritten in the day after. Can somebody help me? thanks in advance
Target OS: Raspberry Pi
Re: Save detailed data over 24 hours
Post by waaren » Thursday 05 April 2018 1:14
cd "domoticzdir"
# open domoticz database
sudo sqlite3 domoticz.db
-- file to receive output
.output t_schema
-- send schema of temperature table to t_schema
.schema temperature
.quit
edit t_schema (to give table different name and add a primary key. This will prevent double entries)
CREATE TABLE [Temperature] ([DeviceRowID] BIGINT(10) NOT NULL, [Temperature] FLOAT NOT NULL, [Chill] FLOAT DEFAULT 0, [Humidity] INTEGER DEFAULT 0, [Barometer] INTEGE
R DEFAULT 0, [DewPoint] FLOAT DEFAULT 0, [SetPoint] FLOAT DEFAULT 0, [Date] DATETIME DEFAULT (datetime('now','localtime')));
CREATE INDEX t_id_idx        on Temperature(DeviceRowID);
CREATE INDEX t_id_date_idx   on Temperature(DeviceRowID, Date);
to: (schema of table in historyTemperatures.db)
CREATE TABLE [HTemperature] ([DeviceRowID] BIGINT(10) NOT NULL, [Temperature] FLOAT NOT NULL, [Chill] FLOAT DEFAULT 0, [Humidity] INTEGER DEFAULT 0, [Barometer] INTEGER DEFAULT 0, [DewPoint] FLOAT DEFAULT 0, [SetPoint] FLOAT DEFAULT 0, [Date] DATETIME DEFAULT (datetime('now','localtime')),PRIMARY KEY (DeviceRowID, Date));
CREATE INDEX t_id_idx        on HTemperature(DeviceRowID);
CREATE INDEX t_id_date_idx   on HTemperature(DeviceRowID, Date);
create new database with one table
sudo sqlite3 historyTemperatures.db < t_schema
create file updateHistory.sql
attach 'historyTemperatures.db' as ht;
select count(*) as entries from ht.HTemperature;
insert or ignore into ht.HTemperature select * from main.Temperature;
create a cronjob that must execute at least every 24 hours but to be on the safe side, I advise to run it more frequent
#!/bin/bash
cd "domoticzdir"
result=$(sudo sqlite3 domoticz.db < updateHistory.sql)
beforeUpdate=$(echo $result | cut -d ' ' -f1 )
afterUpdate=$(echo $result | cut -d ' ' -f2 )
echo Before updating temperatureHistory the table contained $beforeUpdate records.
echo After  updating temperatureHistory the table contains $afterUpdate records.
Please note that if the domoticz developers decide to change the schema of the Temperature table, you have to change the HTemperature table alike.
Have Fun!
Raspberry (debian stretch via berryboot on Synology DS916+) , Domoticz (almost) latest Beta, , dzVents 2.6, RFLink, RFXtrx433e, P1, Youless, Harmony, Hue, Yeelight, Xiaomi, HomeWizard, Zwave, Amazon echo
CaesarPL
Post by CaesarPL » Thursday 05 April 2018 9:54
Why don't you use Influxdb and Grafana?
albercola
Post by albercola » Thursday 05 April 2018 16:44
thank you to Waaren and CaesarPL: I'll try in the WE. I hope to solve my problem with a python script that is a bit easier for me. But I wonder why in a so sophisticated application like Domoticz there is not an option to choose if overwrite or enlarge the db. Anyway I'll update you about my progress. Thanks again!
Wienen
Post by Wienen » Friday 09 November 2018 14:53
albercola wrote:thank you to Waaren and CaesarPL: I'll try in the WE. I hope to solve my problem with a python script that is a bit easier for me. But I wonder why in a so sophisticated application like Domoticz there is not an option to choose if overwrite or enlarge the db. Anyway I'll update you about my progress. Thanks again!
@albercola; did you find a way to accomplish this? I want the same thing only then for my gas and energy consumption.
Hope you can point me in the right direction Image
Users browsing this forum: No registered users and 3 guests
